Since launching in early June, I keep finding water in the bilge and I can't find the source. I am pumping roughly a bucket a day. Water is clean. I did a test where I vacuumed the bilge dry while at the dock and it stayed dry for about a week. The minute we left the dock water started rising again. The stuffing box isn't leaking. No water in the pan under the engine. No water in the pan where all the thru hulls are located. The next compartment where the shower drain pump is located is also bone dry. No indication of any leaks at the hot water tank or fresh water pump. I'm on vacation so I check the bilge morning and night and I drain about half a bucket each time. It's the first time this has happened since we bought the boat 3 years ago. At this point I wonder if the water could be coming from the keel bolts but I think it's unlikely. I don't know how the through hulls are installed on these boats. Is there anything accessible under the pan?
Wondering if anyone out there has experienced anything similar. It's a real head scratcher.
