Oh, and that's a whole different rabbit hole.
Boat had all Raymarine ST60 wind, depth, speed, ST4000 Autopilot and Raymarine 435i chartplotter. The 435i worked well but because the area we boat, it was very slow when zooming in and out due to being very busy and lots of data to process. Saw the new Axioms at the Boat show last year and decided on the Axiom 7 in the spring. The dealer I go to gave me the boat show price and I saved $150 - 200. When I was installing it, in order to get the ST instruments to talk to the Axiom I needed a convertor $ 150. Didn't have this before but thought that was cool so went ahead. Once it was in, also discovered needed a different cover as I had installed it flushmount and the unit I bought was a bracket mount. $ 50. I also went to connect the VHF for DSC. Had this before and it was a direct wired connection, but the new Axiom doesn't speak the old NMEA, so another $150 convertor...... I'm so glad I save $ 150 on the unit for Boat show pricing.
All that aside, I am enjoying the new plotter. I like the touch screen zoom and responds instantaneously. I also like having the various options of info displayed on the plotter. Only issue so far that it doesn't keep the chart poitning with my Heading up and I end up with a sideways chart quite often. I'll need to do some more research and contact Raymarine to sort out. The area we boat, the channel is often an area on the water 50 - 100 ft. wide between submerged rocks just below the surface, so need quick repsonding location and data.
BTW, I completely removed the macerator and capped off the outlet on the tank shortly after we bought the boat as the hose from the tank to the macerator was left full by the PO and was stinking out the aft cabin . Being on the Great Lakes, will never need it and used the thru-hull for the anchor washdown pump.
