Sailing an AeroRig
Apr 5, 2009
3,322
Makes sense. Trimming it out so that the leading edge is perpendicular to the boom, and the boom perpendicular to the wind sounds like the way you’d trim a symmetrical spinnaker on a pole. Gives some lift instead of pure drag.
That was my thinking and it really improved the speed. Now he has a new tool in the belt.
Apr 5, 2009
3,322
I did experience the problem of tacking a fathead in little to no breeze. The wind died down just as tried to tack and the main stayed inverted due to the compression in the 7 full battens. Having seen this problem on the Volvo boats, I suggested we send a crew up the mast to jump them through; a duty the owner's 12-year old son happily volunteered for. He went up the mast and had a ball jumping on the vertical trampoline while hanging no a string. He was making jumps out 10' - 12' out from the mast which would push the batten into a big "S" and then pitch him back out. We tried the bottom batten first, then one at mid height and finally all the way to the top but while it would come close, we could not get it to pop out to the other side. In the end, we had to drop the full height of the sail and then carefully rehoist make sure that each batten was properly flexed to the starboard side. Once we had 5 knots it would pop through without any assistance but it was a no-go less than that.:facepalm:
In less than 5 knots TWS I wonder if it would be better to adjust the battens to carry less compression. That might fix the inversion problem. And in less than 5 knots TWS (especially much less) the airflow will tend to separate and stall around too severe of a curve, so a flatter sail might do just as well or better.
Apr 5, 2009
3,322
As far as I know, there is no way to reduce the compression in the full battens of a large roach sail. The weight of the sail creates the compression. The only way that we could reverse the curve was to push it to the side we wanted while it was supported by the boom inside the stack pack. As soon as it lifted, it loaded up and curved. In addition to that, on this boat you cannot control the boom angle because it is a solid extension of the mast itself. There is no vang or topping lift because they are not needed and could not affect any movement anyway.
You could attach the anchor to the halyard with a slip knot, set the anchor to heel the boat over and yank on the slip knot, let the righting moment of the boat snap the battens over. Of course, dropping sail and re-setting it seems like a lot less work and a more sure bet. ;)
-Will (Dragonfly)
  • Ha
Likes: Hayden Watson
Apr 5, 2009
3,322
You could attach the anchor to the halyard with a slip knot, set the anchor to heel the boat over and yank on the slip knot, let the righting moment of the boat snap the battens over. ...
-Will (Dragonfly)
Little hard to do in 60 fathoms!
Sep 9, 2024
3
Cal 34 Mackinaw City
Really enjoyed reading your AeroRig story! I’m taking a look at a custom built aluminum sailboat that has an AeroRig or similar setup. Although I’m somewhat sold on the performance and relative simplicity of parts. I’m unsure it’d be affordable to own/maintain one. Just doing some searching online and there’s not much info, not a great sign.
This specific boat is around 40’ and I’m curious if anyone has any insight here. I’m inspecting high stress points for cracks later today. It’s been sitting on the hard for years. It does look to be in rather good condition considering but need to look closer.
Apr 5, 2009
3,322
This boat is still in my Neiborhood, and I have not heard of any structural issues. The mast on this one is carbon fiber and with no shrouds or stays, there is no a lot of maintenance except for greasing the mast bearings.
3
Good to know. I just got back from inspecting it. After 15 years on the hard it actually looked good and it did swivel on the bearing. It’s a custom built Bruce Roberts design with a AeroRig like mast but the company Forespar actually built it for the owner.
There was even an extra bearing.
I’d probably jump on this, but the ‘pilot house’ which was also the salon part of the boat was too low for me to stand up in. At 6’1” and my girlfriend at 6’0” we were craning our necks. I’m not sure it would be realistic to drop the floors a few inches. It’s too bad!
Apr 5, 2009
3,322
Is there enough clearance under the boom to raise the roof? That would be the easier option. Remember that with the AeroRig, the height of the boom is a fixed dimension because it is a rigid connection to the mast.
Sep 9, 2024
3
There was around 2 inches or less of clearance above the aluminum bimini. I found 2 inches of foamular insulation between the ceiling panels. The panels themselves were tongue and groove, 3/4 inch thick.
Floor to ceiling was 69” and I’m 73” tall.
Could potentially remove the foamular and replace with thinner panels but lose some R value. Or use 3M thinsulate/similar product.
The more I think about it though, I’m not sure it’s worth it. It’s been sitting outside for 15 years and the bilge was full of coolant and rainwater. I’d likely need to replace the majority of the equipment. On the plus side the rigging looked great. It pains me to not be able to pull the trigger!
dLj
Mar 23, 2017
5,161
That is very low head room for a boat that size... Nice looking though... Even I'd have to bend over and I'm not 6 feet tall. I would find that pretty uncomfortable.
Looking at your pics, I would look into lowering the floor over raising the roof but there would have to be a lot of things right with that boat to entertain that much work.
dj
