yes the crank turns easyThe hard part is done. Decide how much of the rest you want to take on. I agree with @kloudie1 - do the valves, seals, and bearings while you're here - especially if you're keeping the boat. You should be able to get a rebuild kit that has most of the stuff you need. Then, you'll have to add things like pistons, rods, and sleeves that don't typically come in the kit. You'll have to shop around and see what's available.
If you get queasy, check with a few machine shops and see what they want to put it back together for you including the cylinder head work.
I know it's a bit of cash, but I don't think I would mess with the old sleeves and pistons. Also, replace any rods that you damaged.
You're doing great!
I assume that the crank turns now?
If you can get the oil seals without damage, yes. Especially if they are weeping. If the crank pulley won't budge easily, make a judgement call. Use the correct puller for the job, typically NOT a three jaw hook on the pulley rim. But, if you can get the seals it would be a good idea.Any other suggestions before I put her together? Im not taking the crankshaft out journals on the rods look good, thinking about the front oil seal? I should replace it? Thank you for any ideas or suggestions, Hunter Healer
Watched all three videos, awesome. Inspirational!As a bit of a guide.
Here is a guy with limited tools and knowledge pulling off a complete rebuild of a 2 cylinder Yanmar.
Inspirational.
gary
He did take the head to a shop...its been some time since i wrote my questions but I finally got around to taking the head off, i found the rings rusted to the piston liners, so i brought the head to a rebuilder who has a good reputation here in Annapolis.
