Raymarine Speed Transducer Blanking Plug
jviss
Feb 5, 2004
6,745
Tartan 3800 20 Westport, MA
I need one, older ST60 speed transducer. I want to clean the paddlewheel, but there's no plug present in the boat.
Thanks,
jv
Feb 10, 2004
3,940
Hunter 40.5 Warwick, RI
To just clean the paddle wheel use a tapered wood bung. You should have a real blanking plug for haul-out to avoid damage to the wheel and also on general principle. I have a ST-50 speed transducer and mine has a threaded cap on the top. But yours may be different- I found this one on eBay, I'm not sure it is the one you need:
jviss
Feb 5, 2004
6,745
Thanks, Rich, I found that one, too! :) Was thinking it's low risk to just buy it.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Likes: jviss
Feb 21, 2013
4,638
According to Airmar you will need a part number to determine what model you need. To locate the part number of this sensor we will need the number on the white tag that is wrapped around the cable. The link below will assist you with finding the tag.
Gemeco | Transducer ID
Likes: jviss
jviss
Feb 5, 2004
6,745
Thank you! I hope the label is still there!
Feb 21, 2013
4,638
These photos are from spare in the box ST60 speed/temp sensor, blank, monitor and cable. The 2 photos on the left are front and back of the cable tag. Oddly the blank looks exactly size the same as my installed blank.
