Help with old plumbing
May 16, 2017
63
Pearson 10 Meter 39 Westport Ma
Can anybody tell me what these are? The black ones screw together, the white ones appear to just snap together.
I haven't seen anything like them in my local home supply store.
The tubes are stiff like pex, but not the same dimensions. The outside diameter is half an inch. Pex is measured by the inside dimension, I believe. At any rate push to connect fittings sized for pex do not fit
Any help would be much appreciated.
7,164
CC 30 South Florida
This the new plumbing to repair and replace the old plumbing. They are called Pex pipes and joints. Of course you will need new tools and training. They are not cheaper than the old plumbing but supposed to perform better. It really helps the plumbers work faster and do more jobs at your expense.
May 16, 2017
63
Thanks, Bennie. I expected pex was in my future.
Does anyone have any idea how to transition from this stuff to pex? I would rather not have to replace it all the way to the head. Replacing from the pressure pump to the galley seems pretty straightforward.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I wouldn't transition to PEX. The black fittings shown in your pic are "Parker O Ring/Grab Ring Tube Fittings." They are, in my opinion, the absolute best marine plastic plumbing fittings available. They are inexpensive, fast, reliable, can be made and re-made many times, and other than a cutter for the tubing require no tools.
They were used on my 1996 Tartan 3800 with polybutylene tubing. This material has fallen into some disrepute because of failures in home construction. I am doing all my new plumbing with LLDPE tubing. It's food grade, rated for the temp range seen on boats, and cuts easily with a $25 tubing cutting plier.
I have zero leaks of any kind. My boat holds the water pressure for weeks with the power off. I highly recommend these fittings and tubing.
You can get them from U.S. Plastics:
U.S. Plastic Corp. | Plastic Bottles, Tubing & Fittings, Tanks, Buckets, Pipe, Sheet & Labware
Likes: LloydB
jviss
Feb 5, 2004
7,089
Fittings:
Parker Fittings
Tubing:
LLDPE White Tubing
The fittings are available in black or white. The tubing is available in white, red, blue, green, and black; so, if you want to color-code your plumbing, you're all set.
Cost is very reasonable. Fittings are a couple of bucks each (typically under $3 each) and tubing is $15 to $22 per 100'. The only other things you'll need is a cutter, $8.55:
Complete Soft Tube Cutter
Fittings are available in pipe threads, too, to transition from brass/bronze to plastic, to connect to pumps, etc.
I bought a variety of fittings, first from making a plan to re-work some goofiness a prior owner had done, then to have spares on hand. I can do anything with my plumbing now, and quickly.
Jul 7, 2004
8,481
Hunter 30T Cheney, KS
Interesting topic. I was thinking of replacing my 30 year old PB plumbing in the off season. I was going to go with PEX since I've worked with it and have the tools. First thing anyone should do is sketch their system as is, and then plan how it's going to be replaced. I'm my case I'm planning to organize it more, possibly with manifolds, and color code hot and cold lines. I'd like to build in and easier way to winterize the system and bypass the water heater.
jviss
Feb 5, 2004
7,089
Amen to this! That's why I like the Parker fittings for this. I just un-do the fittings to the water heater (by hand), and I have a short piece of LLDPE tubing with fittings stashed nearby that I use to bypass the heater. I drain the heater into the bilge and let the bilge pump remove the water. I disconnect the water tanks form the manifold and let them drain similarly. I drain and shut off my accumulator (via a ball valve). Then I undo the input to the water pump and put another short piece onto the pump and drop it into a gallon of pink. One gallon, more or less, and I can pink the entire system.
It would be a bit nightmarish to do this with Pex. The Parker fittings easily connect and disconnect by hand.
jviss
Feb 5, 2004
7,089
By the way, @MightyMike , since we're neighbors in Westport, I'm happy to give you a demo of the Parker plumbing fittings, and show how it's laid out on my boat.
This past weekend I saw you were still on the hard. When are you going in?
May 16, 2017
63
QUOTE="jviss, post: 1639674, member: 66876"]
F gzittings:
Parker Fittings
Tubing:
LLDPE White Tubing
[/QUOTE]
Ah, jviss, I wish I had seen your post before heading down to the boat this morning. I stopped at Home Depot on my way and picked up an bag full of pex tubes and fittings. I have cut and fit all the pipes from the pump to the water heater and galley. I am still left with making the transition back to the original tubes for the run to the head. Your links should be very helpful.
May 16, 2017
63
They launched me today in the middle of my plumbing project. It's great to be in the water, even without running water.
Thanks for the kind offer.
jviss
Feb 5, 2004
7,089
You're welcome, let me know if I can help.
I think it's unfortunate you missed my reply before investing in the Pex stuff. As you can tell, I'm a strong proponent of the LLDPE tubing and Parker fittings on boats, and a detractor of Pex in this application. The main reason is that Pex is not meant to be taken apart. You have to cut stuff to take it apart, and it might not be possible to put it back the way it was. The copper rings will tarnish with time. Just not good on boats, in my opinion. The Parker fittings and polyethylene tubing are so easy, and only require one tool, the tubing cutter, are are infinitely undo- and redo-able. This comes in handy for winterizing and recommissioning.
Jul 7, 2004
8,481
Since the investment has already been made: with the crimp tool kit the crimp rings can be cut without damage to the PEX tubing. If you can use Sharkbites it's even easier.
May 16, 2017
63
I do like the greater flexibility of the LLDPE. In the short lengths I am using pex might as well be copper, it is so stiff and unforgiving.
jviss
Feb 5, 2004
7,089
I can let you try out a piece of LLDPE. It's not soft like fish tank tubing, but definitely softer than Pex.
jviss
Feb 5, 2004
7,089
@MightyMike I'm going to place an order with US Plastics, if you want anything and want to share shipping costs please let me know ASAP.
May 16, 2017
63
Thanks, jviss. If it's not too late, could you add four 1/2" tube to 1/2" thread couplings two male thread and two female s and two 1/2" tube to 1/2" tube straight connections.
I think I can reuse connections from the tubing I have removed, but having new pieces would be cheap insurance.
jviss
Feb 5, 2004
7,089
To be clear:
Please ack.
capta
Jun 4, 2009
4,920
I used the white ones for my watermaker low pressure plumbing. Blue tubing is fresh water and green is salt. My Pearson was built w/the black ones, but I prefer the white as they are just push in/and out so no wrench is needed to tighten and no threads to wear out. In time I'll switch all the black to the white ones on my fresh water system. They come in two (and three) way valves, so I'll be able to turn off each line at the manifold and I won't have to drain the whole system to work on one line.
jviss
Feb 5, 2004
7,089
What are those white connectors called, and where do you get them?
BTW, the black ones don't require tools, you make them up hand tight.
jviss
Feb 5, 2004
7,089
To be clear:
Please ack.
@MightyMike I placed the order, I'll bring your stuff to Westport when it comes.
