Stainless question
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
Clearing out my mom’s house and the admiral comes across a fish poacher. An oblong stainless steel pan with a rack inside. Only thing is it has a pinhole leak a few inches from the bottom. Any ideas for a fix? J.B. weld?, epoxy? Has to be food safe and take heat...Google is not helping except for a TIG weld...
Jan 5, 2017
2,490
I agree with google, tig would be best. Silicone would be easiest and cheapest. I sure miss the shop at work when I need to do things like that. Not chemist enough to know if J.B. Weld is food safe or not.
I agree with the weld. You can have it welded, though I thought you Could weld stainless. Then of course grind it smooth and polish it.
I'm a chemist. Answer.... NOT! go with a weld.
dLj
Mar 23, 2017
5,181
You can weld it. Gtaw (tig) would work no problem. It's likely a 304 stainless steel. Welds quite readily.
dj
Beneteau 323 Annapolis MD
Smack the hole or the surrounding area, might close the hole so it does not leak? Put a screw in it?
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
If the material is thin and you decide to have it TIG welded, make sure the welder has experience with thin material. Or you will have a really big hole.
I like the smacking suggestion:plus:
6,060
Hi Mark, Rail Makers in Everett works with SS all the time and could fix that hole in a jiffy. Call them first to make sure. They do first rate work.
