I have a ProFurl B29S furler that was original to my 2000 Beneteau 311. I am the second owner. I bought the boat a half dozen years ago and had a terrible time with the upper swivel in the furler until last year. Previously I had to crank the jib all way up with a winch, and never could get the luff tight, and had to use all my weight to pull the jib down, not a good situation and potentially dangerous. Last year with technical support from ProFurl, I figured out that the part of the upper swivel that keeps the furler aligned with the luff groove had become a little crooked and was twisted a little across the luff groove and was binding. I was able to realign the lower half of the swivel with the luff groove by giving the lower part of the swivel a good, hard twist to get it back into position. The upper swivel then slid up and down easily.
After that "fix", I ordered new bushings for the swivel so that the swivel would not be so easily misaligned due to worn bushings, to be installed before launch in the spring. I was finally able to access to the mast last weekend and removed the upper swivel. I found that the new bushings don't quite match what I have in my furler. The new bushings are mostly round on the inside and do not have the shoulders on the inside that keep the furler aligned with the luff groove and keep the lower half of the swivel from turning independently of the luff groove (pictures below).
Here is the existing furler, the bottom side that aligns with the luff groove. Note the "shoulders" on the bushing and similar but smaller ridges in the inside of the furler.
Here is the top of the furler, the part that is free to turn around the luff. This bushing is also free to rotate in its track. It does not have the same shoulders, but the metal ridges inside the furler are also visible in this picture.
Below are the new bushings I was supplied. Note that they appear to be identical and neither has the "shoulders" to align with the luff groove and keep the lower part of the furler from turning around the luff.
I have two questions for the group:
1. Do I need the bushing with the "shoulders" to make the upper swivel of the roller furling work properly? I think I do, but I don't really know. I have called ProFurl (now part of Wichard) multiple times, and left three messages, but this year they will not return calls. Last year's service was excellent but the person I talked to last year is no longer with them.
2. I have obtained a nearly identical upper swivel from a friend of a friend of a friend who changed his rig. This second furler looks the same except the inside metal part of the upper swivel does not have the raised ridges inside that my existing swivel has. The bushings in the second furler are in better shape and the swivel appears to less used than my current one. Will this second furler work on my boat? Below is a picture of the bottom half that aligns with the luff and groove.
Thank you. I need to figure something out in a couple days so I can launch my boat.
