Started hooking up our potable water hose to the boat's pressurized water connection that bypasses the potable water pump. Got tired of the time and effort to make it leak tight with channel lock pliers. Just installed quick disconnect hose fitting. Problem solved and saves time to connect and disconnect!!.
Has anyone else done this?
