Solar Panel Type and Installation Tips
Oct 10, 2017
23
Hunter 41DS Westport Marina
Hi All. I have a Hunter 336 and am looking to install a solar panel over top of the bimini cover at the stern. I talked to a person last year who had a terrible experience with the solar panels that he bought. The quality of the panels were very poor and they delaminated/deteriorated very quickly and he had to replace them. I have two questions that I am looking to get some advice.
1. Is there a type/brand of flexible solar panels that you would recommend?
2. Are there any tips you can give me regarding mounting them on top of a soft bimini cover?
Thanks in advance for any info.
Geoff
Solbian panels are probably the best panels for attaching to a soft surface, they are not budget minded. And here's an article to help install them.
One issue with solar panels and their efficiency is heat, hot panels will not produce their rated power. Panels mounted on a frame will allow air to circulate beneath the panel, helping to keep it cool.
capta
Jun 4, 2009
5,099
I'm not a fan of the velcro idea for us. If we were to mount a few $800.00+ panels on our bimini, I would definitely want to use them on crossings and not have to worry about losing them in a sudden 60+ knot squall in the middle of the night, at anchor or at sea.
There must be a better way to attach them to a bimini.
I also wonder if direct attachment wouldn't cause the back to heat up excessively, making them less efficient and last a shorter time?
Mar 1, 2012
2,182
My flex panel has been mounted on the bimini for years, and many miles, with zero problems. Sad to say, it has reached the end of it's life and needs replacing, which has me a bit stymied since I haven't found another flex panel like it. It's just lashed to the bimini supports at the four corners.
Some flexible panels are not up to be installed on something soft, like a Bimini. They are flexible in the sense the panel can be fit to a modestly curved surface, such as the top of the hard dodger or on deck with the deck's camber. They are flexible but need firm support under the panel. The one that failed might have been one of those.
Then there are really flexible panels that can be rolled, they might work better on a soft surface.
When I was planning my solar install, I considered the Solbian panels and ultimately opted for a marine grade rigid panel that is mounted on a SS frame above the Bimini.
In the world of solar panels you get what you pay for.
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
I have 2 flexible panels on my Bimini. I tried similar snaps to a mainsail cover for the first one I had before adding a second panel. I have the 2 panels temporarily connected to each other with zip ties and the corners tied/secured to the Bimini tubing for now. I need to have some work on my Bimini and when I do, I intend to use these Loxx fasteners. Sold by sail-rite, on amazon and other places. Kinda pricey but looks like they will do the job.
videos on fasteners from sail-rite
Likes: Rick D
Jan 4, 2010
1,037
Farr 30 San Francisco
Sunpower makes a very similar panel to Soliban and I think is a bunch cheaper. Sunpower cells are among the best.
SV Delos showed an installation of flexible panels recently -
They sewed an extra pocket on their Bimini that the panels could fit into, so they aren’t likely to get blown around. Doesn’t solve the problem of getting airflow under them though.
Jul 1, 2010
990
Catalina 350 Port Huron
I put 420 watts of panels on our bimini last year. I used Renogy flexible panels. Way too early to be able to tell you how long they will last but so far so good. I'm sure they won't go as long as rigid panels, so not expecting that. Being able to do a low profile mount rather than deal with building an arch was more important to us. I had to beef up the bimini by adding rigid struts in place of the straps. I also added fiberglass battens under the fabric and up over the center arch to keep the panels from hitting a hard spot at the point over the center arch. See pics below.
To attach them, we used 3-m Dual Lock (part # SJ3440 for the fabric side and SJ3870 for the panel side from itapestore.com). The dual lock on the bimini fabric can be sewn in place with a decent machine. My wife did this and also added the pockets for the battens. The panels have been through 60 mph thunderstorm winds last season without issue.
Mar 20, 2011
624
Sesmith. Thanks for input and I like the idea of adding battens to support on Bimini. One problem I’m having is sag on my Bimini due to added weight of flexible panels.
Jun 14, 2010
2,485
:plus:
Don't let them flex repeatedly, or they won't last! I've been using solar panels since 2001 and have been through 4 generations. The latest are 2x Renogy 160w panels and a single Lensun 50w ahead of the mast. Mounting on the (curved) deck was done with 3M VHB 2-sided tape. No holes and it holds well even in high winds and decks awash (especially the amas).
I should add that the Renogy quality is not great, but the output has been good and (so far after 2 years) they are holding up (after 3 early returns). The eyelets are brass plated steel that rusts. I would recommend Sunware or Solbian, at a higher price point. Lensun is also good quality. I stuck with the Renogy only because they exactly fit the area (see image) but the defect rate of the new ones was not good. Hopefully these will last (they're inexpensive so I have a spare still in the box).
Jun 14, 2010
2,485
Any suggestions for running the wiring through bulkheads??
Interior bulkhead? Just avoid chafe - perhaps rubber grommet or extra shrink-wrap or electrical tape on the wire itself. If exterior, there are numerous thru-deck fittings that are water tight.
May 7, 2012
1,625
Hunter e33 Maple Bay, BC
Jeff, add Gioco flexible solar panels to your “will consider” list. They are one of the few that are recommended by MaineSail. I used a backer board and 3m velcro on all 4 sides to attach to my bimini and after 4+ years have had no issues. Jeff Cote at PYS in Vancouver can assist with whatever you need. You will find him very receptive and very easy to work with. For years he has writen monthly articles in Pacific Yachting Magazine and a while back he wrote a couple about installing flexible Solbian panels (450W total) on his Catalina 36. He carries both Solbian and Gioco.
Here are some videos that you may find helpful.
Pacific Yacht Systems - Solar
