For whatever reason when I reinstalled my heat exchanger the space was a bit tight for the exhaust hose. I have the newer HX with the hoops for mounting. Saw these and was wondering if they were worthwhile as there is nearly an inch between the front of the HX and the rear of the motor there.
www.mrcool.us
Also hoping the clamps can be opened up so you can slide them around rather that on from the ends.
Mounting Bracket - Universal 3 inch
Stainless Steel Bracket set for Universal Heat Exchanger Note there is one for the 3 inch series and one for the 2 inch series. Order based on your heat exchanger diameter. The coolers that use this mount are: 302631 200420 201027
