- Oct 22, 2014
- 24,502
Perhaps a poet and don't know it.. I have trouble with meter and rhyme... some of the time...You could have been a poet!
For clarity sake,enhanced GPS
Thanks. I just assumed it is similar to the system we used for underwater surveying. I'm still not clear on how the enhanced GPS system works, but that's OK. I'm an old timer just happy that my chart plotter shows me were I am.Enhanced GPS (or E-GPS, EGPS, trademarked as eGPS) is a technology designed for mobile phones on GSM and W-CDMA networks, to augment GPS signals to deliver faster location fixes, lower cost implementations and reduced power and processing requirements.
That was LORAN A. Used it from the Mexican border to Kodiac Island, Ak on the commercial fishing boats (salmon, crab, etc.) when I was a teen.I used to use Loran C when i flew. Our set had a built in osciliscope, where you would identify the master station and then march the three slave stations into alignment . Its all a matter of time difference from the master to slaves, which is very similar to how Omega used to work and exactly how GPS does work. I dont think there are any ground station transmitters still working. Keep it for a souvenir .
Perhaps a poet and don't know it.. I have trouble with meter and rhyme... some of the time...![]()
The cell towers are fixed and can use the tower signal to improve your location calculation.Thanks. I just assumed it is similar to the system we used for underwater surveying. I'm still not clear on how the enhanced GPS system works, but that's OK. I'm an old timer just happy that my chart plotter shows me were I am.
I remember using Loran A flying for the Air Force. On the oscilloscope, we would manually move the master and slave signals until they were superimposed. The oscilloscope would provide the time difference that the signals were received. These time lines were printed on the navigators chart. So, much like celestial navigation, this would give us one line of position. Loran A's range for ground waves was about 100-200 miles, but at night the signal would bounce off the ionosphere and could be used in excess of a thousand miles.I used to use Loran C when i flew. Our set had a built in osciliscope, where you would identify the master station and then march the three slave stations into alignment . Its all a matter of time difference from the master to slaves, which is very similar to how Omega used to work and exactly how GPS does work. I dont think there are any ground station transmitters still working. Keep it for a souvenir .
Exactly what ours was on the transport We flew a full time navigator on the plane aircraftI used to use Loran C when i flew. Our set had a built in osciliscope, where you would identify the master station and then march the three slave stations into alignment . Its all a matter of time difference from the master to slaves, which is very similar to how Omega used to work and exactly how GPS does work. I dont think there are any ground station transmitters still working. Keep it for a souvenir .
I like hanked on jibs. I like having a suit of head sails to choose from.Ah, those were the days......
Hanked jibs, rotary phones and LORAN A. lol
My first big boat came with 23 bags of sails. Everything from storm jibs to gargantuan light air spinnakers. And one of my favorite things to do was change headsails on the foredeck in 40+ knots of wind; NOT!I like hanked on jibs. I like having a suit of head sails to choose from.
I think if I were ever to commission a cruiser... I'd have a roller furled Geneker way out on the sprit for those lighter air days and a solent stay set up aft of the forestay that I could hank a selection of heavier-wind head sails. I imagine that being the ideal set up. I also imagine that I'd really like a gaff main but maybe that is just the romantic in me.![]()
You have a lot more experience that I do. All of my cruising has been coastal to VA and NC or in a lake. I've owned 7 sailboats in the past 18 years and only the last two had roller furled headsails. I have not liked the sail shape on either once I start to furl. I remind myself they are not called roller reefers but furlers. What I have found on my Hunter is that she will sail very well with headsail only. So my first reef is to the main, the second is to take the main all the way down, the third is to roll in about 25% of the head sail and if it is still too much, I pack it in and motor. I can keep my H26 comfortable to about 25 mph and then I give up. .... The only solid point to connect a solent stay would be the U-bolt in the anchor locker but I'd have to leave the locker open or drill a hole in the hatch... (hmmm...that actually might work... ????) It would be really nice if I could quickly deploy a small heavy jib. I think a second set of reef points in the main would also be nice. If I could keep my boat on her feet in the 30 mph range, I'd call it a win.Very few cruising boats today use hanked sails and there's a pretty good reason why. If you choose not to, then that is your choice, but I doubt you'll be doing half the sailing as those with infinite reefing at the pull of a string.
John, I think that is AGPS (Augmented) not EGPS. Operative words being "I think".For clarity sake,
GPS is a satellite system. A GPS navigation device, GPS receiver, or simply GPS is a device that is capable of receiving information from GPS satellites and then to calculate the device's geographical position. Using suitable software, the device may display the position on a map, and it may offer directions. We use on boats hardware and software to display this information on Multi Functional Displays (i.e. chart plotters)
You don't often cross from the states to the Caribbean and sail down there, do you? lolI've never had a jib hat roller furled. Always hank on sails. My current jib has reef points, just like the main sai. I is a working jib size, and reefs to storm jib. Never needed
