I have a Hitachi LR180-03B mounted to my Yanmar engine. One of things I have never gotten around to doing is changing out the ground cable. I disconnected the original 10 AWG positive cable that was connected to the Starter post and ran a new 4 AWG cable to the Positive Distribution Bus that links directly to the House Bank. But I didn't change the ground because the access is so difficult and it weighs heavily on my mind because it is still a 10 AWG that is buried in a cable bundle and comes out at the engine ground post. I'm told the alternator ground should be run back to the negative bus, which should have one large cable that is connected to the engine ground post.
I was confused by empty post in the photo until I saw in the alternator specs that there are 2 ground posts and either one can be used. It was difficult to get my eyeballs on the other post, but with a camera, I get a peek at the post that has the original ground cable. It was difficult to trace it into a bundle but it appears again at the engine post. I think I'm going to have to take out the entire alternator to get this sorted. Any advise is welcome!
Next, I saw that Compass Marine has a very good "How To" article featuring a replacement alternator with external regulator .... hmmm. Anyway, I see in one of the photos that @Maine Sail has put a jumper between the 2 ground posts. Good idea or not necessary? Attached is one last photo of the Engine Ground. It seems that the terminal lug is in pretty rough condition. I better do something about that too. I wish the access was better. I could barely get a hand in there to take a photo with the phone!
