Hello,
Hoping to get some help regarding repacking the stuffing box on my new-to-me '85 O'Day 28'. I'm trying to repack and no matter what I do I cannot seem to get the lock nut loosened. I'm attempting from the port lazarette if that's helpful.
Things I've tried:
Attached is pic of the stuffing box. Any help would be greatly appreciated. I've spent roughly 3 hours toiling in the port lazarette to no avail.
Thanks,
TJ
Things I've tried:
- Loosening with 14" heavy duty pipe wrench and lock nut wrench
- Spraying with WD40 Penetrating Spray (not regular WD40)
- Putting pipe wrench on and tapping with Ball Peen Hammer.
- Which direction do I go with the lock nut and the stuffing box nut?
- I understand to loosen I need to grab both with wrenches and bring the wrenches together, but I'm not sure which I'm to bring up and which I'm to bring down.
- Clockwise and counterclockwise are ambiguous since I'm not sure which way is "in" if you understand me.
- If you could put it in terms of "towards port" or "towards starboard" that would be helpful.
- Any tips on loosening?
- All I've accomplished is rotating the whole shaft with the wrenches and simultaneously cutting up my hand.
- I have Liquid Wrench coming in the mail and am hoping that works better than the WD40 Penetrating Spray.
- Make/Model/Year: 1985 O'Day 28'
- Engine: Original Universal Diesel M50 10hp
Thanks,
TJ
