No.does it matter what brands?
Surge breaks work well when stopping while going forward, are there surge breaks that work backing down a ramp?I would use hydraulic "surge" brakes
The principle of surge brake operation says that the brakes will apply whenever the trailer “pushes” against the truck while in motion. The reverse side effect of this is that in reverse, the truck can “push” against the trailer also causing the brakes to apply................are there surge breaks that work backing down a ramp?
I was thinking in terms of arresting motion if backing too fast while descending the ramp with a loaded trailer. The vehicle applies brakes, the trailer pulls on the tongue, the load strains the vehicle brakes. If the surge breaks can work in both cases, pushing or pulling, it can go a long way to relieving wear on the vehicle brakes alone.in reverse, the truck can “push” against the trailer also causing the brakes to apply.
Hey Will,If the surge breaks can work in both cases, pushing or pulling, it can go a long way to relieving wear on the vehicle brakes alone.
My 2 cents for what it’s worth.We have old and very poor drum surge brakes, which have finally failed. I'm currently in the process of installing disc brakes (some of the hardware is sitting next to my computer as I write this). So take my untested advice on discs with a very large brick of salt...
Regarding backing up with disc brakes: Some disc brake actuators (e.g. Demco 8605101) have an electric lockout, that activates via the reverse-light circuit, disabling the brakes while backing up (so you don't lock up the brakes as described above). The reverse-light line is available on a 7-wire trailer wiring connector, but not on the 4-pin. Some people put a 5-pin connector on the trailer (you can get a 7-to-5 adapter just like the standard 7-to-4's, but adding the reverse-light line).
That all sounds great, but when backing the trailer into the water, we generally disconnect the wiring. So (I think) the brakes would tend to lock up on the prep area (probably not on the ramp itself, as the boat is pulling backward on the surge brake actuator). I asked eTrailer.com if any of the actuators with electric lockout also has a manual lockout that I could use on the ramp. They said they didn't know of any that offered both. So I'm planning to add this valve ($12 @McMaster-Carr, rated for high pressure, so appropriate for brakes). Maybe someone more educated than me will tell my why this is a terrible idea...
Note that the disconnect you might use with an extendable trailer tongue would also accomplish the same thing (they disconnect the hydraulic line when extending the tongue).
Thanks - that's a really good point. I probably should have said that I expect I'd use / appreciate the electric lockout mostly when parking the trailer or backing down my own driveway. On the ramp, there's plenty of other stuff to do, and saving a few seconds disconnecting is the least of my worries.My 2 cents for what it’s worth.
Although the electric lockout feature sounds good and I’ve had trailers with that feature I didn’t actually find it necessary.
My practice of backing up a trailer is to get out and do a walk around to check things, remove tie downs, warn people I don’t know what I’m doingetc while I’m doing that I put the manual override in place and disconnect the electrical before I back into the water.
Always a safe practice to get out and walk around before you backup.![]()
Curious about what you decided to do?Once again thank you all for the advice
