Hunter Passage 42 1995
Feb 21, 2014
137
Hunter Passage 42 St Andrews Scotland
Hello everyone. I am thinking Terry might answer my question before others. I would like to replace my propeller shaft on Casper my Hunter Passage 42. Could anyone tell me the correct length and all dimensions, key way at the coupling end etc?
Thanks Scallywagger (Bill)
Jan 4, 2006
7,771
Do not, under any circumstance, use someone else's dimensions for an expensive job like this. Boat dimensions will vary slightly for any number of reasons. They're not like a car.
If you're doing the job yourself, copy your dimensions exactly. If not , put the job in the hands of a pro, most definitely NOT a wharf rat :yikes:.
Feb 21, 2014
137
Okay thanks for the advice. I had actually thought though that these were a production line yacht. It's just the arrangement for the hoist and remaining in the slings is only 48 hours to allow antifouling. I had been trying to put everything in place. However, thanks for the advice.
Jan 4, 2006
7,771
This is true, they are the product of a production line. However there are often slight differences between the same model boats and this could cause an expensive error.
Thinking about it now, one problem I can imagine encountering is the exact location of the strut. I can think of several minor differences in exact hull shape which COULD cause a slight difference in the strut location and hence a difference in the shaft length. Again, all possible slight differences.
Replacing the shaft is a major undertaking due to any number of corrosion situations you will encounter. You would also be replacing the cutlass bearing sleeve which is more time. Replacing the transmission coupling is also very likely depending on the corrosion back there. Take a look here to get some idea of how much work goes into just this one small ancilliary detail:
For the shaft replacement see here:
How about dropping the rudder to accomodate the shaft? Removing the prop which will not come off to save your soul ? Lapping in the old prop on the new shaft ? Maine covers all that as well.
Odd, don't you leave your boat on stands when bottom painting or anything more than 1/2 hour for an inspection and zinc change ? Here, that's the max time you can tie up the lift. How do you paint under the slings ?
There are numerous things you can plan and prepare, before the boat is out of the water. When and IF I were ever to do this work on my boat, I would plan for roughly a week between out and back in. And that includes harassing the machine shop to get off their bloody duffs and get to work on fitting up the new shaft :angry:.
137
Hello and again thanks for all the thoughtful advice. I threw a blade in 2017 whilst away from home with Casper and she was lifted by a crane to get at the propeller. The original propeller was removed and I drew the shaft out past the rudder. The yard had a good, used volvo folding propeller which was machined to fit the shaft in the work shop and the shaft replaced on Casper and the propeller fitted. This was all done quickly in order for me to return back over the North Sea home and back to work. I have now bought a 20" Max prop more suited to the Passage 42 and will go through the same sequence of events.The propeller is used (although in almoast new condition, the taper will not match the shaft) and I will need to be matched it to the shaft. Hence my idea to buy another shaft and have the engineering shop machine both prop and shaft ready for fitting when lifted out. It will be a new stainless rod made into a shaft if you understand what I mean? It is actually the correct length and diameter I require.
Dec 25, 2000
6,059
Hi Bill, just read your post and those that have replied have offered very sage advice. Unable to provide the prop shaft length, sorry. Never had a need to measure and to do so would require that I haul the boat, which at this point is a few years away. Very pleased with the performance of our original fixed three plate and no plans to change.
Feb 21, 2014
137
Hello Terry, good your alive and Kicking Okay everyone, I'm guessing now I will wait for a major lift out and draw the shaft and take all the correct measurements.
Much appreciated, Bill Smurthwaite (Scallywagger)
Jan 4, 2006
7,771
For myself, I have never looked back and regretted overspending on a job when everything went to my satisfaction. On the other hand, I never forget and always regret when I have cut a corner somewhere and the final result was less than I had expected.
Mind you, that is the opinion of someone with OCD who never knows when to quit :yeah:.
Good luck with the replacement in the future.
Likes: Scallywagger
