My Merit 22 has a single reef point in the (bolt rope in mast and boom) main sail, but no provision on the boom for reefing, so I'm setting up for simple slab reefing. every place I look seems to show the cheek block and fixed anchor mounted at a different angle from the lowered reef cringle, so I figure I'll ask here also . one common illustration shows the fixed end of the reef line almost vertical below the reefed cringle and the cheek block mounted back about 45*, I assume the theory being the fixed side of the reef line holds the foot of the sail down, wile the cheek block side pulls it back on the boom?? seems reasonable I guess?..... thoughts?
The other thing that peaked my interest is one site that mentioned mounting both the fixed point and cheek block on the same side of the boom so the bunt of the sail doesn't get bunched up beneath the reef at the rear of the boom. this seems to me a reasonable thought for a couple reasons. less sail wear and a neater reef, as well as allowing the reef point to set more consistent and lower on the boom. thoughts?
