Engine Mount Life
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
My 410 is now 20 years old. I am wondering if the engine mounts should be replaced. Any advice on engine mount life?
It is probably good thinking, but how do they look and feel? Cracked? Hard? Does the engine vibrate more or is it louder than you're use to?
-Will (Dragonfly)
Likes: kloudie1
Nov 6, 2006
10,152
They'll be bad when the upper steel plate of the mount starts tapping the lower plate of the mount.. usually at idle or low RPM underway.. You can measure the clearance (installed under engine weight load) at three points on each mount, front, aft, and middle.. they should be close and none less than 1/4" or so.. depending on number of hours, exposure to heat or solvents, and a few other things, they can last 20-30 years.... or considerably less.. they are expensive enough to measure carefully rather than just change 'em
7,443
Everything that @kloudie1 says PLUS, if you haven't done an alignment check recently (or ever), notice if the drive shaft axis is much below the prop shaft axis when the flange is first separated. This will indicate if your mounts are failing.
Dec 25, 2000
5,953
Our 1991 mounts remain in good condition. No symptoms at the moment.
