Solar vents in the Pacific Northwest
Oh you’ve been there.
Apr 8, 2011
774
Hunter 40 Deale, MD
Plan B:
Reduce the general complexity by putting in a really good aeolian ventilator.
I installed a couple of Beckson "Vent-o-mate" ventilators with their SS cover piece, about 20 years ago. Vastly reduced moisture and odors inside, year around.
No fan motors to make squeaky bearing noises and no batteries or solar panels to worry about. In pretty much any... breeze at all they really remove air, 24/7.
I will be attempting to retrofit my Lewmar hatches with a similar ventilator product that I haven't seen anyone review on here. Reasonably priced - even at West Marine. It involves cutting a hole in your lexan hatch (yeesh), but same concept as the "Vent-o-Mate, and looks nice too:
LEWMAR Cabin Hatch/Vent & Trim Kit | West Marine
Has anyone else installed one?
Apr 8, 2010
2,251
Just gotta ask.... since Lewmar hatches have had lock-able vent position since the 80's, is this add-on really needed?
Of course, a well designed little aeolian vent will block spray lots better, that would be a decent reason for the install.
When hosing off our decks or driving our boat to windward off shore we Must (!) securely close/latch the forward hatch. :)
774
Hunter 40 Deale, MD
I need it primarily for when I'm away from the boat and need air exchange to keep it fresh down there. Believe me, when I'm on the boat, if the spray's not flyin' the hatches and companionway are gulping air. The factory "dorade" is functionally useless on my 2009 H36 - the merest modern nod to an actual non-poser proper dorade. They shouldn't have bothered.
TFox, What if you set up a low speed fan near the dorade. Say a computer fan. Set the fan to blow the air out of the dorade.
This will set up an air pressure change and you will get air flowing into the boat from any opening and maybe every opening available. These boats are not air tight. You just need to change the air pressure inside the boat.
Apr 8, 2011
774
Hunter 40 Deale, MD
That's an interesting idea JSSAILEM. I'm not sure the throughput would be all that much (though better than zero), and running power to the dorade to run the fan would be a project i'm not keen to tackle. I'd prefer something passive. but good thought.
Apr 8, 2010
2,251
I just focused on the location... Deale, MD. Hot and humid in the summers, would be a guess.
You certainly would want the most air flow possible.
Likes: tfox2069
Apr 8, 2011
774
Hunter 40 Deale, MD
I just focused on the location... Deals, MD. Hot and humid in the summers, would be a guess.
You're spot on FastOlson. Without air exchange below in the hot/humid summers we get here, it gets that "boat smell" pretty quickly. I don't mind it so much, and it dissipates pretty quickly when I open the boat up and get air moving thru it. But it'd be nice not to have the wife make a face when we first open the boat up.
Jan 8, 2020
48
brentswain 31 31 twin keeler Heriot Bay BC
A computer fan, hooked to a main battery ,powered by a solar panel, is the same as a solar vent ,but with much more panel and battery capacity. and far easier to replace any parts.
774
Hunter 40 Deale, MD
Not arguing that a computer fan works well in certain circumstances, the power draw is miniscule, and would run for a long long time on the house battery capacity. They're amazing little things - and the good ones are VERY silent. Agree with all that. But in my case the draw through the Hunter "dorade" is so little that it wouldn't make any noticeable difference, so its definitely not worth the trouble to warrant pulling out my ceiling to wire it somewhere into the battery system. YMMV.
May 16, 2015
114
C&C 37 28127 Port Madison, Washington
Also a PNW sailor, I'd like to replace my cowl vents with low profile marine ventilators. Was first thinking of the solar fan-vent, but after some research and then this thread, I'm going with the Beckson ventilator/stainless. Thanks, Matt for the query and FastOlsen for a simple solution--for me, anyway;)
