Catalina 34 MK II salon table conversion
Jun 3, 2004
42
Catalina 34MKII 1717 Merritt Island, FL
Hello, Can anyone tell me how to lower the salon table for use as a berth. i cannot figure it out. Thank you.....Gary
May 20, 2016
3,015
If it’s impossible to push down like Stu describes, the top plastic centering support is probably broken. Unless the internal strut is centered in the tube it won’t collapse.
1,417
If the table will not go down when you loosen the knob at the base of the pedestal, then remove all screws from the pedestal and find out what is wrong.
PeggyO
Jun 24, 2019
1
Catalina 34 MKII Sackets Harbor, NY
We have a Catalina 34 too. Putting down the salon table is extremely hard. We unscrew the knob then I literally get on the table in a seated position and use my weight (140 lbs) to push it down. I kind of sit and and jump up and down until it goes and my husband also might push at the same time. It usually works.. FYI..I put a piece of plastic on the table so I don’t scratch it.
May 20, 2016
3,015
Here is a photo of the Aluminum centering support I made to replace the plastic piece.
