I've got a Hunter that is woefully under-ventilated, so this has become one of my winter projects. A few questions for those with ventilation experience, especially in the Pac Northwest:
-once the battery is initially charged, can the vent's solar panel keep the fan going consistently throughout the winter months in Seattle, or would I be better off with 12-volt powered vents or a couple passive vents? My plan is to get 2 vents for the main cabin, ideally with one of them pulling air out, the other pulling outside air in.
-the previous owner installed an older NICRO 2000 day/night vent (currently the boat's only vent), installed vertically on the stern. Not surprisingly, it hasn't worked in quite a while and it probably needs a new battery. Not sure if it's worth replacing/repairing though, as I question it's value--all it does is pull air out of an aft compartment (below the cockpit) that houses the fuel and holding tanks, which is sealed off from the rest of the boat by a bulkhead in the aft sleeping berth. Am I missing something here, is there a good reason to have a single vent there? I could replace the old solar vent with a passive vent, as the location and vertical mount would restrict the amount of direct sunlight even in the summer.
Thoughts about any of this would be greatly appreciated! Thanks, Matt
