Shore Power Inlet Location on a C-22
AaronD
Aug 10, 2014
751
Catalina 22 9874 Newberg, OR / Olympia, WA
I'm slowly accumulating parts for a shore-power installation (maybe this winter, or maybe not...). More questions coming, I'm sure. But for now, I'm just trying to decide where to mount the inlet (which will also affect where to put the panel, since we want a short cable run before the main breaker, and that affects what wire and other parts I need. Thus the question now...). Anyone with a C-22 or similarly-sized boat have recommendations that worked for you?
We generally nose in to our slip, so the cord will be running back from the bow.
Locations I've (mostly) rejected:
--Interior of cockpit coaming - I'm trying to avoid having a shore-power cable draped in the cockpit for us to trip on.
--Exterior coaming, near the winch - we almost always step aboard to the side deck near the forward end of the cockpit. I moved bimini mounts to clear that space (that was a big win!) I'd rather not add a cable there to introduce a new tripping hazard.
One possibility: Inlet near the forward end of the cockpit coaming, with panel and wiring in the coffin (we don't expect to need access to any of the AC switches, etc. nearly as often as the DC panel, so putting the panel in the coffin is probably fine. And we already have a solar charge controller in the coffin, so it would be a sensible place to mount a battery charger too. But, we already have plenty of stuff going on in that area:
(in that picture, you can see the inside jib tracks, furler clutch, bimini mount, and a fender clip)
Another possibility:
Inlet near the forward port-side cabin window, and panel on the cabin wall, next to the forward dinette seat. I've already cut plenty of holes in the aft end of the port-side liner, for all the DC electrical (see a picture of that too, for good measure). All things being equal, I'd prefer to separate the AC and DC wiring just a bit. And spreading out all the liner-weakening holes is probably good too.
@Ken put his in the cockpit (Adding shore power: interior questions). But that seems like another way to add an inconvenience draped across in the cockpit.
Some previous posts (including a few by @CrazyDaveCondon) indicate that Hunter 23 and 26 owners often install it inside cockpit lazarettes, but I don't think that's an option for the C-22, as the locker lids don't have a cutout for the cord.
Perhaps a cockpit pocket would be a possibility. We'd still have to run the cord down the side deck, but could tuck it behind the clutch and hopefully keep from tripping anyone.
Thoughts and experiences?
Sep 14, 2014
1,284
Catalina 22 Pensacola, Florida
Put it in cocpit storage pocket in front face of pocket and connect inside from cabin or lazarette if no baffle seperates the fuel compartment (port side) from the cabin.
Likes: Hardhead
AaronD
Aug 10, 2014
751
Thanks @Jacktar. I did a little measuring, and it looks like the Smartplug inlet will fit at the end of the cockpit pocket. After some more thought, I think I can secure the cord coming into that pocket in a way that will keep us from tripping over the cord. We have full-length cockpit cushions, so if nothing else, I can tuck the cord between the cushion and the coaming. I'll post pictures when it's all in place (which might be quite awhile...)
May 23, 2016
1,024
Catalina 22 #12502 BSC
we simply run a cord from dock power 30amp thru 20amp Marinco adaptor to hd ext cord to bow pulpit, then along port side just inside shrouds, up to the slight gap tween poptop/sliding hatch & top crib board corner, to trickle charger on battery which keeps it topped off....eze, no need for a "shore power inlet" IMO on these little boats...ymmv
AaronD
Aug 10, 2014
751
We already have enough solar to keep the batteries in pretty good shape at our current usage. After an extended cruise, it sometimes takes a few sunny days to top off the batteries again, but we've never gotten worryingly low on power.
This is really more forward-looking - to the days when there will be just two of us cruising together. Don't get me wrong - we love sailing with our kids. But it won't be too many more years before our cruising schedule won't be limited by the school calendar, so we'll be out when it gets a little colder. We're going to throw in a small heater (Caframo markets it as a defroster, but 100w is a fair amount of heat in a C-22 cabin). We won't be able to run that very much on our solar.
And - for days on the other end of the heat scale - I'm considering a small compressor cooler (e.g. the Dometic or Alpicool models). Thus the thoughts on 'real' shore power.
Well, that and the fact that I'm a geek and like playing in my shop... (which is probably the real reason).
Sep 14, 2014
1,284
Well there is an advantage to my setup that it keeps the plug inlet dry all the time and lets me lock up the boat and leave the battery maintainer and a night light on while at dock. Looks like someone is at home at dock and adds to faux security.
Likes: Lemon Drop
