Do blisters occur in just gelcoat or gelcoat and fiberglass? If it occurs in just gelcoat, is there any point in using a barrier paint when a PO stripped everything down to bare glass?
I think they'd say, "Run away as fast as you can!"You should probably talk to a professional about the current condition of your boat..
Who ever said there are never any issues? I've seen bilges that had to be reglassed due to water damage.I think they'd say, "Run away as fast as you can!"
If blisters occur in fiberglass as well, how come so many boats can go for years without bilge paint with no known issues?
Are you thinking to buy this boat?I think they'd say, "Run away as fast as you can!"
In addition to the concentration driving force to cause osmosis, there is also The pressure. Hence the reason you see far more osmosis on the outside of a hull, and often lower down, than in the inside. A short quote from how osmosis happens:If blisters occur in fiberglass as well, how come so many boats can go for years without bilge paint with no known issues?
Sanding away VC-17 sucks big time! I'd rather sand away most any other paint.Sanding away bottom paint, even if it is only VC-17, sucks!
If you have ablative paint, power washing will remove some of it, depending on the paint and how strong the power washer is.Wow! That's pretty crazy considering how thin that stuff is. The marina shut off the water before I pulled the boat out at the end of the season so I wasn't able to clean it. Is a power washer going to cause any issues with the bottom paint or fiberglass?
I'm not sure what the gift is, not writing it out? Or writing it out would be the gift? Osmosis is a very interesting subject. I'm kinda guessing some here would consider the former a gift and some would consider the latter a gift... So should we all just say thank you for the New Year's gift and call it a party?I’m resisting the urge to write an entire chemistry lecture on osmosis. My New Years gift to you all![]()
Perhaps just a link to one of the academic papers on osmotic blistering?I’m resisting the urge to write an entire chemistry lecture on osmosis. My New Years gift to you all![]()
What are the variable in this equation? Or the citation of the work you copied?In addition to the concentration driving force to cause osmosis, there is also The pressure. Hence the reason you see far more osmosis on the outside of a hull, and often lower down, than in the inside. A short quote from how osmosis happens:
Me resisting...I'm not sure what the gift is, not writing it out? Or writing it out would be the gift?
dj
Me too. Polyesters and vinyl esters are formed by the reaction between an acid and and an alcohol to produce an ester . The reaction can be reversed in the presence of water (hydrolysis).I’m resisting the urge to write an entire chemistry lecture on osmosis. My New Years gift to you all![]()
