First off thank you all for the help making last season (our first with our 2001 310 #63) a huge success!
We are replacing our current FLA batteries (2xGC2, 1 sealed G31) with AGM mostly due to their age and also due to concerns with off gassing. We do not have shore power but have a 180W rigid solar panel and the stock alternator (50A). Our major drain is the fridge and auto helm as well as charging of ipads etc, All lighting is LED. I'm looking for 100Ah as a budget for weekend and the occasional longer trip. I figure 100Ah is a reasonable guess at our energy budget.
I have read much of the wealth of info available on the forum (again thank you Mainesail and StuJ). We plan to go with 4x GC2 AGM and possibly a reserve if we can fit it in. We are adding a smart(er) charger and an ACR.
If I combine the GC2s into one large series/parallel house bank the capacity should be 440 ah (220 useable). This would be great but I'm not sure I can fit the reserve and worry that I may not have sufficient charge capacity to keep them topped up.
Am I any better off keeping them as 2 separate 220 Ah banks (no reserve) ? Same charging requirements, more switching. What are the thoughts on having two equal sized banks like this? It seems that I would be keeping a lot of our capacity in reserve and drawing down the house bank significantly overnight.
Another thought is to go with 2x Firefly GC31 as a house bank and a single firefly GC31 as a reserve. Still about 230 Ah but able to draw down deeper and the recharging is less critical. I'm not clear if the carbon foam technology has issues still or requires additional mods to the system...
Thanks for any thoughts.
