Extra Bilge Compartment Purpose?
Jan 2, 2017
765
O'Day & Islander 322 & 37 Scottsdale, AZ & Owls Head, ME
Does anyone know the purpose of the extra bilge compartment just aft of the main bilge?
It has a tiny drain hole leading to the bilge (which was clogged and I freed up with a pipe cleaner) and a series of larger holes leading to the side.
I can’t figure out what its purpose is, other than a good place to stash contraband.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
I think just the progression of the bilge profile...there should be one on the other end of the deeper bilge section as well. The other end should have 1 of the keel bolts in it though.
Jan 2, 2017
765
Thanks Greg.
The thing is, it’s not part of the progression. It sits above the channel from the aft section where the stuffing box and engine are, so any water and oil flow under it to the bilge.
Jan 7, 2011
6,017
Thanks Greg.
I did not realize that. So there are separate weep holes from the engine bilge, under the pan you are asking about, to the bilge?
I do admit my little pan is always dry.
I will have to take a closer look next time I am out at the marina.
Yours looks nice and clean !
Jan 2, 2017
765
That’s because I just cleaned it.:)
As the tiny drain hole was clogged, it was partially full of gunk.
See if yours also has the three overlapping round holes on the side.
RoyS
Jun 3, 2012
1,742
I think that compartment was created only as a result of a structural rib crossing there.
Likes: smokey73
Jan 2, 2017
765
Sounds reasonable but why create an additional space reachable through a trapdoor in the saloon sole? Why not leave it open to the underlying bilge channel?
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Is that a Sperry?
I was noticing the same this, must have been a sale on..........
I like the wine cellar idea, but only if its maintained full, otherwise the bottles would have a tendency to roll around........:)
Jan 2, 2017
765
I live in Sperrys.
Unfortunately the cavity isn’t deep enough to hold wine bottles. That leaves a contraband cubby but the ring latch in the sole is a dead giveaway.
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Too many other projects in my queue than worrying about that compartment on my 322! :) It stays dry, I don't worry about it. Now, let's talk about the sliding hatch! That's my winter project...
Jan 7, 2011
6,017
Nope...no extra holes in my small bilge...just the 2 little drain holes.
Mine wasn’t too clean though!
Jan 2, 2017
765
Thanks Greg. Verrrry interesting. Yours has a two tiny holes at opposite corners while mine has just one tiny hole forward, and the three larger interlocking round holes to starboard. (You can see them in the lower right hand corner of my photo.) It's a puzzlement.
Jan 2, 2017
765
What are you planning to do with your sliding hatch, Mickstr?
