I have been thinking about upgrading to a smart plug-with the new plug in the boat and cutting the head off the 30 A twist and lock and putting the new connecter - smart plug on ..
Thoughts?
Thoughts?
Do you take your cable with you when you visit other docks? We don't have any "destination " docks so our cords are woven thru the slip fingers. I imagine guest docks having cords. I may be wrong.Just changed mine (at surveyors suggestion). Left the twist lock on the shore end. It's a much more secure set-up and was easy to do.
Yes or have a second cordDo you take your cable with you when you visit other docks? We don't have any "destination " docks so our cords are woven thru the slip fingers. I imagine guest docks having cords. I may be wrong.
Always. I've never been to a transient dock that had shore power cords available for guests.Do you take your cable with you when you visit other docks?
Thetus has them, but reserve them for folks too far from the outlet, and need to extend their cord.Always. I've never been to a transient dock that had shore power cords available for guests.
Probably took me just over an hour to change the cord end and the boat receptacle. A nice quiet sit-down job while on the boat.How long and easy or difficult was it to swap over?
Very easy to swap Smart Plug Receptacle inplace of Marinco. The cutout footprint is exactly the same, so no new or modified holes. Remove 4 outer screws, loosen screws holding the 3 AC boat wires, reverse that with the Smart Plug , making sure to use Bed-It butyl. Probably 20 minutes including getting tools (screw drivers) out and putting them away.We always take our shore power cords when Cruising, and I would continue to do that, we also have a 30-50 amp cord converter that we always take as we have had times where 50 amp was all that was available.
