power washer sandblaster attachment - Google Shopping
Seen these advertised. Looks like a nice way to do the bottom..... anybody have experience with them.
Thanks!
Bad idea.....Many pressure washers already come with a siphon attachment for soap or bleach etc. I would try adding some "soft scrub" or other slurry type abrasive to the siphon container and see if it works. The theory seems sound to me but I can see how you can run into clogging issues etc.
That is not how it works. The pick up is at the nozzle head and it is aspirated into the stream. Just the same way this post’s product worksPut an abrasive through a pressure washer pump and it will cease to pump. Water and soap only.
he's talking about the soft scrub commentThat is not how it works. The pick up is at the nozzle head and it is aspirated into the stream. Just the same way this post’s product works
So am I. My pressure washer has a detergent reservoir and it does not run the soap through the pump. It is sucked into the wand by aspiration.he's talking about the soft scrub comment
