www.practical-sailor.com
Great article. Thnx![]()
Is Stainless Steel Really the Best Metal for Use in an Anchor? - Practical Sailor
Since 1974, Practical Sailor’s independent testing has taken the guesswork out of boat and gear buying.www.practical-sailor.com
I use this on my trailer with great resultsI see no advantage of the stainless steel option over the galvanized steel option for these anchors. They set equally well, the galvanized may actually be a bit stronger. Carry a can of galvanizing paint and if some spots look thin or scratched, touch it up. Done - no rust to worry about.
dj
Well, it’s still a matter of routine inspection I would guess. Casual visual inspection is enough to see galvanized chain rusting away where rust points have formed. For SS chain you might need a different type of inspection. There are several kinds that might apply, but would many boaters actually take the trouble? It would have been a better article had PS advised its readers on the best way to make inspections of SS ground tackle, etc. One receives “little notice” if one is not taking the time to notice anything. I think the same “little notice before failure” comment could be made of SS rigging, esp. turnbuckles, where owners never have their rigs inspected, or do not inspect it themselves.The PS article points out one of the short comings of SS, i.e., there is little notice that it is about to fail. Galvanized chain will begin to rust.
Absolutely. If any maintenance or inspection task on a boat is difficult or tedious to complete, it won't get done.Well, it’s still a matter of routine inspection I would guess. Casual visual inspection is enough to see galvanized chain rusting away where rust points have formed. For SS chain you might need a different type of inspection. There are several kinds that might apply, but would many boaters actually take the trouble? It would have been a better article had PS advised its readers on the best way to make inspections of SS ground tackle, etc. One receives “little notice” if one is not taking the time to notice anything. I think the same “little notice before failure” comment could be made of SS rigging, esp. turnbuckles, where owners never have their rigs inspected, or do not inspect it themselves.
... difficult or tedious to complete, it won't get done.
Some of these flaws can not be accurately assessed by visual inspection as they are just too small or hidden inside the metal. Often it requires equipment and a tech that are very expensive. That's why there are age guide lines for things like SS rigging, SS fittings, and even chainplates. Unfortunately, some manufacturers use inferior metals (SS 304 instead of SS 316) and this can lead to premature failure.Well, it’s still a matter of routine inspection I would guess. Casual visual inspection is enough to see galvanized chain rusting away where rust points have formed. For SS chain you might need a different type of inspection. There are several kinds that might apply, but would many boaters actually take the trouble? It would have been a better article had PS advised its readers on the best way to make inspections of SS ground tackle, etc. One receives “little notice” if one is not taking the time to notice anything. I think the same “little notice before failure” comment could be made of SS rigging, esp. turnbuckles, where owners never have their rigs inspected, or do not inspect it themselves.
A bit off-topic, but I use this or the Ace brand on my prop each year for anti-fouling. Works exactly like the $30 stuff and it is a larger can. I get two year's application from one $7 can. I've used this for 15+ years.I use this on my trailer with great results
Wait! What?A bit off-topic, but I use this or the Ace brand on my prop each year for anti-fouling. Works exactly like the $30 stuff and it is a larger can. I get two year's application from one $7 can. I've used this for 15+ years.
