Hi to all i have good voltage on the starter motor but when i turn the key noting happen, even no tick noise. I have current on the panel when i engage the start position, so i have a fault solenoid ? beside the starter there is a 4 foot relay i cannot find it on my wiring diagram. I did not try it out. What it does ? Any help will be appreciate.
This is a known Yanmar problem. And it is often intermittent. The issue is an unsized wire running from the starter to the key switch. Coupled with a few corroded connections and there is not enough power to drive the solenoid.
On the starter where the large positive cable from battery is attached is a white wire. This wire is the culprit. It goes from the starter to the key switch and back to the solenoid. The fix is to get more current to the solenoid by replacing the wire. If you search the internet you will find multiple solutions including simple ones, i.e., replace the existing wire with a larger gauge (10 gauge is good) wire to fancy ones involving relays and rewiring.
I changed the wiring on my boat. The power for the solenoid runs from he positive bus bar to the key switch and then to the solenoid. This reduced the length of the circuit and the wire gauge was increased to 10 ga. Haven't had a problem since.
