Torqeedo security
Jun 14, 2010
2,466
I received by new Torqeedo and wanted to make it less easy for thieves, so here's my project. See images and descriptions. I will add another cable to secure the handle, and a brass padlock to tie it all together. This won't stop a determined thief with tools, but it might thwart the opportunist (or make a thief choose easier targets). I plan to add my initials in permanent marker to each piece, in a visible place.
Images here Torqeedo Security
Nov 8, 2010
11,386
Nice. That's the route I would take if I had one. That orange pin always killed me. Just like the 'remove before flight' flags on aircraft, that one should say 'remove before theft'.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Nice!!
In my case I attached a locking cable from the motor to the stern rail, removed/stored the battery and control head and covered the motor with canvas to mitigate the theft risk.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Nice job! It makes me think of how I might have done it. I am fortunate to have a hobbyist's machine shop in the basement, and some nice stock lying around. Would probably have made a new, longer, stainless steel pin for this:
Does it have to be 3/8" diameter, of can it be bigger?
Nov 8, 2010
11,386
Nice!!
That’s a good solution for the boat, but it offers no help when you’ve brought your dinghy to shore.
Feb 21, 2013
4,638
In that event the same cable can lock the motor to an eye bolt on the dinghy stern and the battery and control head removed/stowed in a small backpack I carry while the dinghy is docked on shore.
Jun 14, 2010
2,466
I totally agree. That was the first thing that had to change, and it was one of the reasons I held off getting one of these motors. The new 912ah battery is almost a boat buck -- and cries for a lock. (It's like leaving an ipad unattended in your dinghy.)
I would have liked to use heavier cable (braided) but that would have meant more drastic alterations and some welding/machining to do it right. But where do you stop when even heavy cables or locks don't foil well equipped thieves? This should discourage the average dishonest opportunist, anyway.
Likes: jviss
Feb 21, 2013
4,638
For a boat buck + $695 you can purchase a Torqeedo 503 with the extended range 915 wH battery from Defender.
Jun 14, 2010
2,466
Update- last week I used my Torqeedo again and realized the motor mount (base) doesn’t have a good secure way to lift it one-handed. Yes, I can lift it one-handed but it depends on grip strength on slippery smooth metal. With wet hands (and sunblock) slipping the grip is a risk.
So I added this simple braided polyester loop as a handle. It’s thin enough that it doesn’t interfere with motor assembly, yet strong enough.
Likes: sail sfbay
Feb 21, 2013
4,638
..............realized the motor mount (base) doesn’t have a good secure way to lift it one-handed. Yes, I can lift it one-handed but it depends on grip strength on slippery smooth metal. With wet hands (and sunblock) slipping the grip is a risk. So I added this simple braided polyester loop as a handle................
Good thing the torqeedo is completely waterproof, in the event you inadvertently drop it in the water and reportedly can be immersed at a depth of 1 m for up to 30 minutes without suffering any damage. I will take a note of your handle for my torqeedo.
Jun 14, 2010
2,466
That’s fine in 1 meter of water. I usually anchor in 2+ meters :confused:
Feb 21, 2013
4,638
Captain Larry-DH,
That might be ok so long as long as you retrieve it quickly unlike the 60 lb outboard I dropped into the water that had to be taken home to remove the gasoline, clean, dried, oil changed and recovered quickly to avoid a fuel spill risk.
