Awful!
I have the weekend off. First time in four weeks.
Windy is showing a 1 mph "breeze" with a temp. of 97F.:mad:
Jan 7, 2011
4,790
Oday 322 East Chicago, IN
Could be worse... I pulled my holding tank out today to reset the fittings (1 was weeping a bit). :poop:
30 years of stuff in the tank (actually not too bad) and 30 years of dust, dirt, crud under and around the tank once I got it out...fittings will be remounted tonight, will paint under the tank tomorrow, and tank will be back in on Wednesday hopefully.
You must have some boat projects to do...
I have been meaning to get to the tank for a week or 2, but every time I got out to the marina, the winds were favorable and I said...sail today, projects tomorrow. Tomorrow finally came. :(
Hope things cool down and the winds pick up for you.
Pulling the holding tank in 97 degrees with 1 mph wind is like the worst -squared. Holding tank issues are best treated in March and if the contents are frozen all the better. A tip for those inclined to do this: Go to box store and buy a lot of diapers. Distribute them downhill from any potential leaks. Not perfect but it is seriously upsetting to see a stream of liquid poo running for the bilge.
Sounds to late to ask, but could you not have emptied the tank before you attempted to remove the tank.
Sorry to hear about your poo poo experience. Does not sound like my idea of fun at any time.
Catalina 34 Casco Bay
Pulled my tank after hauling out 2 yrs ago.. Needed to have our septic tank pumped so positioned the holding tank over the septic tank clean out. Released the residual contents and then flushed the tank until odors and water ran clear. Re-installed the tank in the spring with an isolating PVC gate valve. A PVC union joint connects the macerator. Should the macerator fail, it's an easy swap out..
Jan 7, 2011
4,790
Tank is empty. It wasn’t too bad really.
Apr 16, 2017
841
Federation NCC-1701 Riverside
This is the worst time of year to love sailing in the southeast US.
I guess a watched pot never boils
Swivel stick is a pretty neat item. It would be an idea that could be adapted to a fuel pump - fuel hose - setup to spray fuel around your diesel tank to dislodge the biologics growing in the corners, so they can be sucked out.
Sep 20, 2014
1,320
Rob Legg RL24 Chain O'Lakes
Those are the days we are happy for a 86 lbs thrust, 24 volt tolling motor. You can ghost along in complete silence, same as you do when you sail. Not quite as good as sailing, but at least your not sitting in the middle of the lake doing nothing.
Incidentally, "I Boated" ... Are you sure about that??
Dec 28, 2015
1,850
I installed a remote tank rinse system in my rv tank it looked like a small lawn sprinkler. Worked well but I can't seem to find one to install on my boat tank
