My original Jabsco on my 1999 H280 had a vertical crack on the pump assembly tube and was leaking when I pumped the toilet. I decided to replace the whole pump assembly with a new one. After installing the new assembly it leaks water. Specifically, I pull the handle up (this is to drain the toilet waste) and it draws water from the toilet, when I push the handle down it sprays water out where the flap valve is installed. I have taken it apart to verify the gaskets are installed properly. The flap is genderized so it can only go in one way. All the screws are tight. I am probably missing something obvious but I am stumped. Any input would be appreciated.
