Beat the Heat
TomY
Alden Forum Moderator
Jun 22, 2004
2,768
Beating the heat, good thread today.
This worked for us during last weekends heat warnings. First, we sailed a lot and didn't motor much. You can get a cool breeze powering into a headwind, but the engine still builds up heat onboard and below. Sailing to windward even in light breezes, cooled us well even requiring a fleece layer one evening.
But we had to turn downwind eventually. We sailed one morning in a light breeze with just the main and mizzen. The main was too much bother (on our boat) in the heat and once you start turning downwind our main becomes blanketed by the genoa (or vice-versa).
The trick was to bring the apparent wind just forward enough to sweep the deck and cockpit.
The reason we turned downwind was to get into the upper reaches of Penobscot Bay. The air temperature gets warmer as the distance to the open sea increases, but the water gets warmer.
That paid off as the swimming and wading, in water temperatures in the mid to upper 60's, were wonderful in the heat. Plus we rigged our awning before high noon and had that shade to live under.
The photo above and the one below were taken at about 7 am. The sun was already hot. It was wise to do our hiking, swimming early before it became too hot. Early morning was a pleasant time to take a good row.
One other thing, we didn't do much cooking below for the obvious heat generated. We used the grill, hanging downwind of the cockpit, more often.
We partially steamed these lobsters at home and kept them cool in the ice box. At about 7 pm one night, they were split, brushed with hot butter and fresh basil leaves, and grilled for 5 minutes on each side.
They went well with chilled local greens and a cool Rose'.
YUM!
You could always make a nice cold lobster salad roll, but I think some things are worth a little heat exposure. YUM!
-Will (Dragonfly)
TomY
Jun 22, 2004
2,768
YUM!
-Will (Dragonfly)
In fact about my favorite way to eat lobster is in a cold salad or roll.
We're leaving tomorrow for 3 weeks of sailing not far from home. I'm looking forward to not going too far - sailing a lot - and anchoring in some new and old spots. Nothing more.
We'll likely be dealing with warmer than normal temperatures (as will you, Will, by the odds), according to NOAA's month out prediction.
However, they are also predicting normal rainfall. I'm happy with that.
