I need to replace the Seacock in the head from the sink drain. It has become stiff and hard to open and close easily.
I've had some luck using cooking oil in the hose and allowing it to seep down into the seacock, that makes it easier to open. But it still needs to be replaced.
Is anyone using the Bronze Seacocks with the grease fitting attached, that lets you use a grease gun to lubricate them?
Thank you for the input.
