Wiring multiple GFCI's
Jul 7, 2014
95
Hunter Passage 42 Jacksonville
GFCI outlets have Line and Load terminal pairs (hot/neutral). Connect the Line terminals to the source power, and the Load terminals to any additional downstream receptacles/devices you want to protect.
A ground fault on the GFCI outlet itself or any of the outlets connected to the Load terminals will trigger the GFCI outlet to trip, disconnecting its own outlets as well as anything connected to the Load terminals.
It should be obvious at this point, but if you connect additional outlets in parallel using the Line terminals, they will not be protected from a ground fault.
EDIT - This page has some diagrams that should clear this up - https://www.do-it-yourself-help.com/gfci-outlet-wiring-diagrams.html
CYQK
Sep 11, 2009
605
beneteau first 42 kenora
Obvious is that in the original question all will be gfcis
Jul 7, 2014
95
If they're all GFCIs, then they'll each have their own protection. When you use the Line terminals, they behave like any other fixture connected to a common hot/neutral. If you use the Load terminals, they protect anything connected on that side.
May 24, 2004
7,213
CC 30 South Florida
Survived riding a bike without a helmet and now sailing a boat without GFCI. Could it be we had better automobile drivers back then and not too many electrical appliances on boats.
