Hurricane Barry <TS Barry < PC2 < Invest 92L
Feb 14, 2014
7,399
Hunter 430 Waveland, MS
By Wednesday July 10, it will be forming several hundred miles South of Panama City FL.
But there is a HIGH pressure front to Whack it, and move it quickly toward LA & MS.
As normal, the strongest winds are on the North East Quadrant.
It will be probably named as a tropical storm before landfall on ≈ July 13
Maybe wind gusts to 50mph.
Gulf Coast sailors have time to prepare...
Jim...
2,532
Beneteau 343 Slidell, LA
Jim...
Jim,
Thanks for heads up. Hopefully this will be a non event that will negate the need for removing canvas.
Actually, we could use some rain and relief from this awful heat & humidity.
Will definitely keep an eye on it.
Feb 14, 2014
7,399
There was another one about a week back, that ran alone the Texas coast, but never got attention.
This year so far, it High Pressure pulsing from the Pacific Northwest prevents formations.
Five Day forecast 10th-14th.
Not animated but you see all the Highs flowing NW-SE. And the L get "whacked" on the 12th.
Jim...
This what the projected storm looks like on Saturday.
Not a pretty sight. Looks like preparation for this storm would be advised unless the High Pressures that have maintained the nice weather come through and disrupt this one out in the gulf. With Gulf water temps at 86F 30C there is a bit of energy for this storm.
Likes: JamesG161
Feb 14, 2014
7,399
That has changed since I looked. Perhaps the storm will stall as it goes around that HIGH on Saturday 13th.
If the Hurricanes Hunter fly out Thursday we well know for sure.
Jim...
PS: I guess disrupts my sail from Gulfport MS to the Keys:doh:
Only if you want to live forever and not become a statistic that the CG will have to chase down and rescue..
Hell you might make it. It might be a great ride. Might push you to Cuba.
Nov 6, 2006
9,884
Jim, looking at the Gulf Loop Current, as soon as the storm goes west, ya can make some tome going south!
Feb 14, 2014
7,399
Gulf Loop Current
That pushes hot Caribbean Waters to Central Gulf, before the Northern shoreline pushes it back around the tip of Florida.
https://earth.nullschool.net/#current/ocean/surface/currents/orthographic=-75.38,28.43,1186
The Hurricane intensifier and fuel is HEAT content more than Surface Temperatures.
I look at this graphic , and to your point, very on point.
Note the "hot spot" as the central spot on the Gulf Loop in the Gulf.
Also note the wide white area along the coast as the Colder Mississippi River water dump has cooled down the Gulf Shore line, and even the Atlantic Coast gets in the Allegheny Mountains East from all the winter rains/snows.
The Good News is...
This Disturbance is fast moving, reducing its time to strengthen, and that High did "whack" it.
The Bad News is...
It appears to be skimming along the Coast on it Westward Trek. Normally the Low would make and "end run" and follow behind the High pressure front. [as shown on my post#4 Sat-Sun NOAA Graphic]
Longer time in Gulf, more intensification possibility.
____
Too early to predict, Thursday will tell the story.
Still time to prepare along the Gulf Coast...
Jim...
7,399
INVESTitgation 92L just kicked in for models to start tracking it.
HIGH pressure is Whacking it.
Some are saying it will be a summer time squall.
Keep on with the preparations and keep your "weather eye" out....
Jim..
Feb 14, 2014
7,399
They are scheduled for a flight this afternoon.
That means this non tropical storm needs real internal storm data and not just Satellite data.
After their flight, we will know chances of intensification, and if the "spaghetti models" have any meaning.
The Good news...
Fast moving over cooler waters along the coast.
Jim...
PS: Non Tropical means it didn't form in the Tropics. Why important? Tropics Contain a lot of Heat.
PSS: This disturbance actually started over Georgia, on land, on Monday.
2,532
Jim,
Tropical tidbits is a great resource; hadn’t seen it previously. Definitely provides in depth analysis. No sensationalizing; just the facts.
Feb 14, 2014
7,399
First Hurricane Hunter mission into PC#2
No eye wall, not much wind, not a named storm, yet.
Highest winds speeds on their flight path, at sea surface was at 12 knots.
Look at their flight path [set by satellite info] and not the satellite cloud cover.
Jim...
PS: Look at the spaghetti model runs after 8 pm EST tonight for more reliable info.
Feb 14, 2014
7,399
what are the red numbers? Wind direction?
No, the orange/red numbers are over the Yellow numbers. Yellow ones are official NOAA weather stations, buoys or official weather stations aboard ships at sea.
I am really not sure about red ones.
My guess is... elapsed time into the flight, that the last data from the Yellow stations reported into NOAA.
Synchronization , so to speak.
Jim...
Nov 6, 2006
9,884
Jim, looks like yall are in the clear except for high water.. I just got in from doubling lines and adding a couple of spring lines.. I don't think our marina on the north shore and up the bayou, will see a lot of wind, but probably looking at 4-5 feet of water over normal. Home in Baton Rouge, we'll probably see a lot of rain and some wind.
Feb 14, 2014
7,399
My guess is...
About red/orange numbers... was WRONG!:redface::redface:
So I couldn't fine any seemingly similar weather readings.o_O
So... for SBO users of the Graphics of HH Recon flights, I emailed the Source of it!
TropicalTidbits.com
The Provider of that website is "Levi Cowan".
He graciously responded to my email with the answer on the orange numbers...
"Hi James,
Thanks for the compliment! The orange numbers are the pressure reading at each ground-based station in the same format that you would see it on a surface map. For example, "124" = 1012.4mb.
Hope this helps,
Levi"
A short bio from Levi...
"I have been tracking tropical cyclones closely since 2002, and am currently a graduate meteorology student at Florida State University."
All I can add, is what I told him...
"You [Levi] have the best scientific information and discussion available that I have found."
Check out all of his great weather analysis!:clap::clap:
Jim...
