H356 diffult to reach the main sail leach line
Oct 7, 2016
68
Hunter 356 Little Creek, Norfolk VA
I couldnt adjust the main sheet leach line because it is over the bimini. I am too short to reach it when the main is fully deployed.
I was able to reach it when i partially furled the main. But i am sure the line doesnt properly work when some of the sail is rolled up in the mast.
I also realized that the large main and small jib has the advantage of furling the main first to keep the sails balanced. That allows the jib to be fully deployed with its proper sail shape longer.
It's better to be a bit oversight than flapping. Flapping will degrade the sail cloth. An overtighted leech line will degrade performance a small amount. I'm 6' and can reach at least 8' and didn't adjust that line very much. To do so put me in a precarious position and at risk of falling overboard.
Oct 7, 2016
68
Yes. That was my position; not safe. But I needed to tighten it.
Jun 25, 2004
1,109
Next time you buy a new mainsail, pay the extra to have the leech line installed so that you adjust it at the tack, rather than on the lead. The loft runs the leech line from the clew up to the head, through a block, and down to down to the tack. It’s worth the extra money. Or you can modify your existing sail to add the “Over the head” leech line installed.
Likes: clmooring
Nov 8, 2010
11,386
I created a reply saying the exact same thing, but then noticed it was a furling main!!! ;^)
Deleted that one!
Feb 6, 2008
86
Hunter 41 Punta Gorda
See if your sail maker will add a small block at the clew and extend the leach line along the foot of the sail. It is the same as going over the top and down the mast. If you tie the leach line to a small cleat on the boom near the mast it sickens the line when you furl the sail and you won't forget to ease it out. We used this on our h41 with in mast furling and it worked great.
Likes: clmooring
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I am very interested so maybe a little drawing could show how you doing that.
Nick
Jun 1, 2009
1,860
Hunter 49 toronto
I have the perfect solution
What you really want to do with a leech line is snug it up once the sail is out, and always release it before you furl
Unfortunately, is impossible to do this in most situations because the either the boom is too high, or you can’t reach the small cleat that was installed in the sail.
Here is a great way to do this
Install a small dinghy cam cleat on the aluminum piece of the outhaul pulley. To do this you will need to drill & tap 6-32 screw holes, and cut the screws to the exact length so that they don’t interfere with the pulley
Now, you pre-set the line into the cleat before you unfurl. Set a large knot or loop in the end of the leech line.
Make yourself a “specialty tool”, i.e. a coat hanger with a hook bent into one end.
Then, once the sail is unfurled ...
You reach up with the “tool”, grab the end and pull, pulling the line tighter into the cleat.
Just before furling, reach up, and snap the line out of the cleat
This works amazingly well
Likes: clmooring
Oct 7, 2016
68
Are these photos from an actual real world instance of this solution?
