Heat Exchanger 1988 Volvo Model 2003
Mar 16, 2009
303
Hunter Vision-36 Richmond
On our new (to us) boat, a 1989 Beneteau First 35s5, the Volvo Model 2003 needs a new heat exchanger. I pulled it out last weekend. It had been leaking onto the starter and causing corrosion on the starter, elbow, head and block. I pulled the exchanger (what a job) and brought it home for cleaning. The corrosion was so bad it looked like a rock inside and the outer housing just crumbled when I tried to disassemble it.
The Volvo dealer wants $1,900 for a new heat exchanger.
Does anyone know of an after market source for this exchanger?
Thanks,
Mike
Pearson P303 #221 RockPort Maine
Thanks,
Mike
Mike sorry to hear about your problem.. That's a Volvo for ya! Anyway, without details on your engine, we can only guess as to what you have...
Go to this link and you might be happy!!!
https://www.parts4engines.com/perkins-4-99-bowman-heat-exchanger/
however, alway's give more info. Thanks, Capt. Rob
Kirie-Elite Elite 37 Niceville, FL
Call Marine Parts Express. They have numerous used volvo 2003 engines and parts. Marinepartsexpress.com/
JRacer
Aug 9, 2011
1,393
Yes, this! I've found their personnel to be knowledgeable and helpful.
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
Parts4Engines, in the UK, will ship to your door at prices that are unreal low!
Apr 8, 2010
2,237
Plan B: you are not too far from the US headquarters for Betamarine. :)
That Volvo HE design with the salt water leaking down onto the starter is a well known design defect.
If you are planning to keep the boat, and it is a good all around design to own for the long haul, consider this upgrade.
