P42 how close are you able to sail to the wind
Jan 1, 2014
181
Hunter 42 Upper Chesapeake
How close are you able to sail into the wind? close hauled to about 35 deg.
Can I do better.
1991 passsge 42
Batten main, loose at the boom
150 Genoa roller furling
2010 north sails - fairly heavy
Can you control physics?
http://newt.phys.unsw.edu.au/~jw/sailing.html
Here is a write up of the physics of sailing with vectors and forces identified. Your P42 is limited in speed by weight, hull shape, and drag. So suspect your 35 degrees may be apparent wind angle but 45 true. Or your speed is reduced by attempting to sail so close to the angle of the wind.
Jan 1, 2014
181
Got the physics part (that is a nice link) ... mainly looking to see if I am truly getting the best I can given the design trade offs made by the designer and manufacturer that made this a comfy cruising boat versus a highly tuned racer.
Can definitely tell the sweet spot just ( the sails seem to set well visual based on tell tales) before speed loss as moving closer to the wind.
Dec 25, 2000
5,945
Hi Keith, ditto here. The ST-50 wind instrument on our boat gives a pretty good gauge relative to wind angle. Belle-Vie does quite well up to around 28 degrees apparent. Power begins to reduce below that, but so so to around 25 degrees. If I see a strong puff approaching I will pinch to about that as the puff arrives to reduce pressure on the boat. Once it passes I'll turn back to regain boat speed.
Jan 1, 2014
181
I have definitely taken advantage of the gusts to improve my line. I was going to put this out there as well ... how do you setup your jib sheets? Not happy with my current as sometimes the line falls below the winch when hauling when winds are 15+. Don’t have picture of my current setup will take one this weekend
Dec 25, 2000
5,945
Unsure of the nature of your situation. Our genoa sheet layout remains as they came from Hunter. I've made a few mods, such as a plastic shroud pipe to stop shroud sheet chafe. Each sheet extends from the genoa clew cringle, to the cheek turning block back by the aft cabin, then forward to each winch. Never had a problem with the sheet falling off the winch, even in apparent winds of 25+ close hauled, or in any angle of attack.
I'll try to remember to take pics of our setup as well, but I suspect they should be the same.
Jun 1, 2004
8,224
According to your description you do not use an adjustable lead block which would control the leech and foot tension on your genoa .... a very important element of headsail trim. Although the aft mounted cheek block works well as a turning block because it maintains a constant angle to the winch you still need some way of controlling the lead angle of the sheet from clew to deck. If this is the case I suggest you reconsider your setup by adding a pair of lead blocks, preferably on track mounted movable cars that allow you to adjust fore and aft movement of jib lead.
11,386
The boat for sure has a genoa track, he just left it out of the description.
Dec 25, 2000
5,945
It does, a long one with an adjustable car. Sorry for leaving that out. Just did not seem a part of Keith’s issue.
Jan 1, 2014
181
Has a led block along the track that adjusts. It runs to the aft bock and then up to an winch (aft side of cockpit) I have two very large winches in line with the hatch at the front of the cockpit. These are great winches but a pain to use with dodger setup. The aft winch has issues when more that a single wrap is around it when pulling in jib. The angle up to the winch from the aft block just doesn’t seem to be the best. I will contend that often user inexperience likely comes into to play as I have a large variety of people that go out with us and often the winds are 8-12 and really not an issue at this wind speed/tacking speed.
Dec 25, 2000
5,945
Normally use a minimum of three wraps, or four if the wind is up. That 150 genoa packs an enormous amount of power when the wind is 15+. Also loads of fun, especially close hauled with all sails up. Belle-Vie does pretty well up to 25, but over that time to take a tuck or two. Never had a problem with the winches or genoa sheets. Eager to see your pictures.
So, in rereading your last post, it seems you have another set of winches aft of the two large ones in line with the forward part of the cockpit? Those are for the genoa. The aft ones, which we do not have, are for the staysail.
Jun 1, 2004
8,224
Your primary and secondary winches can be used in anyway you want. If the dodger prevents a clean entry of the sheet to the primary's drum, you might consider installing another turning or foot block to give the line the rear entry option. If the winch is too close to the dodger for you to get 360 deg grinding.... and you're forced to ratchet instead, you might consider moving the winch back far enough for the winch handle to clear. (On my smaller boat there is adequate clearance but I strip in the sheet by hand and ratchet the remaining line once it becomes tensioned because it's just easier on my body.)
If the secondary winch you're using for your genoa sheet now seems to have enough power but you want a better entry angle... I would suggest relocating the turning block somewhere in front of the winch. Your genoa track may be long enough to do this easily.
Mar 26, 2011
3,751
Corsair F-24 MK I Deale, MD
Can I do better.
1991 passsge 42
I assume you mean AWA, which is an inexact measure at best.
What about the GPS tacking angle and SOG at a given windspeed? that will tell us far more.
Sep 30, 2013
3,602
I was going to suggest using the chartplotter (if so equipped) to determine maximum VMG for the "sweet spot" when close hauled.
Am I off base?
Dec 25, 2000
5,945
Hunter designed the boat so that the genoa winches were in the best location for maximum performance; ditto the staysail winches. If it were my boat, I would make alterations to the dodger so that genoa winch use was convenient and effective. Our dodger does not interfere with genoa winch use.
Nov 8, 2010
11,386
I'd suggest using a true digital compass to get heading, and not course. You course-to-course tracking angle will include side-slip, adding 5-10 degrees to the total. This is an interesting number of course, but not great for direct boat on boat comparison that always use heading.
Aug 2, 2010
529
J-Boat J/88 Cobourg
Curious why you say that AWA is inexact? I have always thought TWA was the inexact one by instruments since it is a calculated value while AWA is simply measured.
Nov 8, 2010
11,386
Because aparent wind is always relative to true wi d . Always calculate angles to true wind. It’s what the pros do.
Mar 26, 2011
3,751
I'm not so sure. On boats that make a lot of leeway (the last cat I had), that is an important component of the tacking angle. I am assuming zero tide and current, of course. Of course, you should measure BOTH COG and heading for maximum learning. No disagreement there. I tend to look closely at leeway, because many cruising cats and non-board beach cats really need to be kept moving to limit leeway. It is an important balance.
And yes, I meant AWA is not a great measure of pointing. In light winds the AWA will be less than in strong winds for the same pointing angle, for example, because of hull speed limitations and the effect of waves; the true wind will have increased disproportionately more than boat speed, and the rest is trig.
