Need some winches
Jun 4, 2019
17
Catalina, Newport Catalina 22, Newport 17 Landlocked in NE PA
I need new winches.
I found a pair of barient 10 winches on Craigslist ... Will they fit?
Grotto
Feb 18, 2018
273
Catalina 22 Wilmington
i assume you mean will they fit into the existing mounting holes. Unless they are the same as the old ones “ barriant 10’s” I would not count on it. I would repot and drill regardless maybe even put in a backer while I was at it.
Jul 7, 2004
8,403
Hunter 30T Cheney, KS
Just so you are aware. Parts for these old winches are expensive and have to come from Australia. Ask me how I know. FWIW, I'd find a cheap pair from a brand still in business.
May 23, 2016
1,024
Catalina 22 #12502 BSC
assume they're for your C22....wait (if you can) for the 2 for 1 price from Defender, WM, and others, happens a couple times/year, then no maintenance/worries on old winches...
Jun 4, 2019
17
Ok thanks.
The pair I found on Craigslist were only $100 but I'm not sure they'll work plus they aren't self tailing.
It sounds like I'll be able to sail her well enough to know whether or not I love the boat without them
Nov 12, 2015
87
Catalina 22 Lake LBJ
For what it's worth.... I don't have winches on my 22; the boat had been modified for racing with winches on the cabin top (which I removed), it has blocks w/ cam cleats where winches normally are located. I find I am fine without winches for my leisurely day sailing adventures on the lake.
Likes: KX50002
Oct 10, 2013
127
Catalina 22 Minneapolis
Yeah, I use my winches as a handy place to wrap lines, but I never actually use them as winches. I mean, I never use the winch handle.
Likes: KX50002
Sep 30, 2013
3,544
I like my cabin top halyard winches, would not be without them. But if I had it to do over, I might not have any jib winches.
Do you have a pic of your block-and-cleat setup??
Oct 10, 2013
127
Yeah, I don't use my jib winches (except to wrap the lines), but I would like a cabintop halyard winch.
Nov 12, 2015
87
My cabin top winches were for the jib I'm fairly sure- cross sheeting for racing. I'll look tonight to see if I have pics of the block/cleat set up-- they are very handy, mounted on a thick aluminum plate where the winches go.
Likes: Gene Neill
Nov 12, 2015
87
Here is a pic, my mistake in that they are not located where the winches were- they are further forward.
They work great for the jib sheets.
