Just went in and Water levels are about to breach here in Bowmanville.
From the picture, it looks like the forestay is right at the cross beam of the travel lift so that is as far in as it can go. I guess they could have come from the other direction but ... maybe not.Wow, i’ve never seen a sailboat carried so far back in the travellift before. Your keel almost outside the wheelset. Is that typical for you guys?
Yea. For sure, that Travellift is at the upper length range for sailboats.From the picture, it looks like the forestay is right at the cross beam of the travel lift so that is as far in as it can go. I guess they could have come from the other direction but ... maybe not.
Yea. For sure, the Travellift is at the upper length range for sailboats.
Not sure if it's typical for a C30 with bow sprit. Last year I wasn't around when they put it in and pulled it out.Wow, i’ve never seen a sailboat carried so far back in the travellift before. Your keel almost outside the wheelset. Is that typical for you guys?
That Travelift positioning looks positively unsafe. Many of the marinas around here pick up the sailboats and launch with the bow facing out. I have never seen one picked up without having the slings pretty much centered on the Travelift frame.View attachment 165084
Finally, gently placed and made ready for this coming weekend. New batteries on deck going in …
Very close friends....So you had 5 adults, mountaineering gear, skis, and full winter camping kit in a 22' monohull sailboat and everybody had a great time?!?!
That's awesome!
