Cracked Muffler
Apr 5, 2019
44
Catalina 310 323 Brooklyn, NY
This original 2007 muffler has less than 400 hours on it. It was weeping water just above the mounting screw. After sanding the area, I found this hairline crack. Repaired yesterday with Marine-Tex and will test this weekend. Has anybody seen this before?
Apr 5, 2019
44
View attachment 165459 This original 2007 muffler has less than 400 hours on it. It was weeping water just above the mounting screw. After sanding the area, I found this hairline crack. Repaired yesterday with Marine-Tex and will test this weekend. Has anybody seen this before?
Updated: Marine-Tex repair failed. Having a pro repairing it this week ...
Apr 5, 2019
44
The Auqalift is special order (approx. 5 weeks) form Catalina Direct. I doubt that Vernalift fits in the OEM location on the C-310?
JRT
Feb 14, 2017
2,039
Cool what was the process and cost compared to new?
Apr 5, 2019
44
Found a local fiberglass muffler repair guy through the manager at Summit North Marina, DE. $400 which is same cost as new But it was done in two days instead of four to six weeks.
JRT
Feb 14, 2017
2,039
Sounds good, always interested to follow C310 issues and solutions!
Jun 14, 2018
1
Catalina 310 somers point nj
Hi Do you have the Name/contact information of fiberglass muffler repair guy? Thanks in advance .
May 20, 2016
3,014
A bit of polyester and FG tape would have been less than 10% of the cost and very easy repair in the boat. Mine cracked around the inlet tube, about a hour job to fix it up.
Looks nice all painted up.
Les
Likes: mnmpizza
