The next job was to deal with the keel lifting attachment area. The original hole had worn through and the PO answer to that was to just drill another hole lower down. I have deiced to cut out the damaged area in order to drill and tap a threaded hole to accept an 8mm eye bolt in the recess. However by this time my aches and pains were back and quite severe so decided to just clean off the keel and apply a sealing coat of epoxy resin to hold back the rust while I try and mend a bit.
