LED bulbs.
Aug 10, 2013
52
Catalina 36 MKII 1721 New London Crockers Boat Yard
I would like to replace my anchor light and steaming light with a LED bulb. Do I need to change the wiring?
Jan 4, 2010
1,037
Farr 30 San Francisco
The new bulbs will consume less current. So less wire is required, no need to change wiring
Mar 13, 2011
175
Islander Freeport 41 Longmont
Be aware that LED bulbs have definitive +/- voltages and so will only fit in existing fixtures one way. Put them in backwards and they don't work.
Have fun
Likes: Whatfiero1
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
Wal-Mart has a large LED light section in auto parts. I took all my bulbs out boat took to Wal-Mart and matched up 5 different types then went west marine And found other one. Found it slightly cheaper at battery+ bulbs store too
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
With LED is all about quality of light. When replacing my cabin lights I bought a few different brands until I found the perfect one. And if you are using them as navigation replacements be very careful to get the correct bulb that is specific for use / visibility rated.
Catalina 34 Casco Bay
Remember to get the correct rated brightness for the size of your boat. Also, as an FYI we had gone LED on the steaming/deck work light. Went back to halogen as there was not enough "good" light on the fore deck.
Likes: NotCook
NYSail
Jan 6, 2006
3,178
Which fixture did you buy or did you just replace the bulbs? I bought a new LED fixture from forespar that I plan on installing....... when I just changed the bulb for the deck it was like you said...... very insufficient. However I understand the fixtures are designed differently.
I don't recall the name of the light maker...possibly Forespar... anyway I had reasoned that the low power consumption anchor light was the way to go.. and by extension also reasoned to save more power and gain bulb longevity I'd change out the steaming/ deck light... WRONG... fore deck light very poor..and, if I'm steaming I'm making power via the alternator so no battery drag down.. I'm back to a total halogen steaming/deck light.
Likes: NYSail
Panera
Jan 18, 2014
61
Hunter 280 Portland, ME
There are two issues with changing to LED bulbs; (1) RF interference where some LEDs will create RF noise interfering with VHF communications. (2) on a sailboat it is important that the lights are capable of proper display while heeling. Many LED bulbs are design to display assuming level such as a power boat. Just things to be aware of search the web, the Coast Guard has published information on this.
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
If you are replacing lights with LEDs be aware of this notice from the USCG:
https://www.dco.uscg.mil/Portals/9/DCO Documents/5p/CG-5PC/INV/Alerts/1318.pdf?ver=2018-08-16-091109-630
Cheap LED lights are often not the worth the money and cause radio interference. Stick with a trusted supplier like www.MarineBeam.com. It will cost a little extra up front but you will be getting a good light. MarineBeam.com also has good information on LEDs in general.
Agreed stay away from cheap LED bulbs.
capta
Jun 4, 2009
5,069
Several things to know.
You need to use colored LED bulbs for red and green or the efficiency is not good.
Most LED bulbs last longer in a sealed fixture and work better/last longer when they have a heat sink, so it is actually cheaper in the long run to buy the sealed fixtures w/heat sink than just replace the bulbs.
I began by just changing the bulbs in the Aqua Signal fixtures, but not being completely 100% sealed and waterproof or having a heat sink, I had to replace bulbs @ about $30.00 each. I have yet to have to replace a sealed fixture LED nav light in some years.
Personally, I can't see any reason to replace the steaming light w/LED as the engine is running and hopefully charging when it is on unless you just want a new fixture.
However, by far the biggest difference is with the spreader lights. We had the tractor bulb style spreader lights and they didn't give very much light, nor did they last more than a few hours. Of course, the ate juice like there's no tomorrow whereas the direct replacement LED bulbs use almost none and give us nearly daylight brightness on deck at night.
Mr Fox
Aug 31, 2017
204
Marshall 22 Portland, ME
I’ll give another vote for marinebeams. High quality product. No RFI interference.
My humble opinion regarding electronics- if you’re using it on a boat, choose a product designed for use on a boat.
Likes: NotCook
Ward H
Nov 7, 2011
3,829
Ditto!
One of the other advantages of going with a quality LED bulb is they are not polarity dependent. You can't wire them backwards.
I also agree about the sealed LED fixture. Will last a long time. If you simply replace the bulb in an unsealed fixture you can have the same problems with corroded contacts and wires.
May 24, 2004
7,213
CC 30 South Florida
It is best to replace the whole fixture with one with LED lights, just replacing the bulbs is a half fix as you will still be at the mercy of the bulb socket and its contact points, also the gaskets get fouled and lenses deteriorate. If you do not want to have to go up the mast any time soon replace the whole fixture.
AaronD
Aug 10, 2014
763
Classic Yachts 26 Newberg, OR / Shelton, WA
:plus: - especially for MarineBeam's sealed units. They're well made, USCG certified, IP-67 sealed, engineered to dissipate heat from the LED unit. And since the entire unit is sealed, they have no spring or screw contacts to corrode. The pigtails are long enough to run into the boat or mast and keep the connections protected.
My only regret: I bought the anchor light with a photocell sensor; it seemed like a really sensible idea. But on my trailerable boat (where we connect / disconnect the wiring during rigging), I found that I'd like to be able to test the light before launching (when it would easy to troubleshoot). And that's generally during daylight, so I ended up taping over the photocell. That won't be an issue for @Cat27rem with a C-28MkII, but something for other trailer-sailors to consider.
Oct 29, 2005
2,366
If you get better ones like MarineBeam, polarity is no issue. It'll work even if +/- are swap.
I changed all to LED except Steaming Light for obvious reason...engine running...no drain of battery while charging.
KenY
