What type of fitting is this?
vetch
Dec 3, 2011
111
Prout Manta 38 St. Augustine
Looking at your picture in the OP the way the larger pipe on the top left is bending as it exits the fitting. That is one to watch out for. You should avoid bending in that area. It will cause the fitting to leak.
Dec 25, 2000
5,756
I don't know the brand name, but they are used in my RV. They work quite well. Finger tight and then a smidge more, and you are good to go.
Hi Tom, what I learned from a manufacturer vendor article a few years ago was to tighten until you hear the fitting start to squeak, then another quarter turn. Seems to work for our boat.
Tom J
Sep 30, 2008
2,309
Catalina 310 Quincy, MA
Sounds good, Terry. But with my hearing, I'm liable to go way too tight!
Jan 24, 2017
666
Hunter 34 Toms River Nj
Mnmpizza,
I had to replace my diverting valve that controls aft and side water tanks a few years back and could not find anything to match.
Lowes home center had bass air compressor fittings that matched up perfectly. Fairly inexpensive Approximately $5.oo.
Five years now and no issues.
Hope this helps!
Likes: mnmpizza
