I think this is a simple problem with an easy solution but before I go drill new holes in our boat, I'd like to tap the wisdom of this group.
I'm finishing up the project of replacing nearly all of our sanitation system on our '92 Hunter 33.5. I replaced the Jabsco head with a Raritan PH SuperFlush. The mounting holes matched up between the two heads but if I leave it as is, I can't reinstall the skirt which goes in front of the head. I believe I have enough room to drill new holes behind the the existing holes but I'm concerned about those holes being too close and thereby losing some structural integrity.
Is there something I can fill those holes with which will set up solid, and then drill my new holes for the new location? Is that the route to go?
Here's what I'm looking at:
