One Of The Most Badly Fouled Bottoms I Have Ever Come Across
Feb 26, 2011
1,428
Achilles SD-130 Alameda, CA
You know, the owner really needs to get a permit before he hires someone to destroy a marine habitat. I bet California will deny him.
Don't quit your day job, Jethro. A comedian, you ain't.
Likes: jwing
Dec 28, 2015
1,848
How do you see anything once you start? I would think it would take hours just for that reason.
Oct 29, 2016
1,915
Hunter 41 DS Port Huron
The bottom is considered a sanctuary hull thereby guaranteeing denial by the local jurisdiction of authority, unless the president of a higher power, known as the department of cgrowth overrules the local authority thought to have jurisdiction at which point the sanctuary hull is granted immunity by all jurisdictions.
Likes: JamesG161
Aug 3, 2012
2,542
A job like that is mostly done by feel.
How do you get leverage? Do you need leverage? Do you just use positive buoyancy? Do you use an attachment? I would imagine you could run a line gunwale to gunwale...
Oh, and that boat needs a weedwacker!
Oct 29, 2016
1,915
Boyle's Law still work in the stomach, but not as fast as your breathing.
Hmmmm... CO2 in the stomach
Just hard to burp with a regulator in your mouth!:cowbell:
Jim...
The hard part of CO2 in the stomach is not burping, its loss of buoyancy through gas seepage through the rectal passage.......:ass:
Nov 30, 2015
217
MacGregor 26S Lakehills, Tx
There was once a 30ft sailboat at the AFRC at Canyon Lake, Tx that had melded with the bottom. Apparently, the requirements the Recreation Center had for using that boat were so stringent that it never left the dock. The person in charge of the boathouse told me that they tried to move the boat, but it wouldn't budge. That was when I dove in and found that the growth on the bottom of the boat was attached top the lake bed 6 ft below.
Jan 25, 2011
2,399
S2 11.0A Anacortes, WA
I saw a Catalina 30 the other day had over 10” of muscles on the entire Bach half the boat. They were scrating with floor scraper and getting more than a gunny sack on each pass. 4yrs since last haul.
I bet if he took the boat out for 30 minutes at top speed 80% would disappear.
I pay $1/ft.
Does your diver ever go to Anacortes?
You would need to check... Think he has all he can handle locally...
