View attachment 163377 I need a piece of g10 to fix an uneven surface inside the hull. The surface where the transducer goes through is not "flat" it tapers inside the hull, the nut inside bottoms out on one side before it tightens. I am thinking to add epoxy and bed the g10 then drill a new hole in the g10 It was leaking when we bought the boat last year and was filled with silicone. I tried amazon and Granger, no luck. Does anyone know an online vendor? I was also thinking of fairing compound over the hull inside and then drill from below to clean up the edge. Will that work? Suggestions on material to use?
