1986 Hunter 34 Owner here: Before I open up the back of the electrical panels, I'd like someone to explain to me how the Main Bilge Pump continues to have power when I've turned off the batteries on the battery switch? On my boat, I've noticed that the bilge pump will run if I have the batteries turned off.
As far as I can tell, it's the only 12v item which stays powered with the batteries all switched off.
I've attached a picture of my breaker panel. I'm going to be adding a 12v breaker which will control the newly installed refrigeration [retro'd the icebox]; and I'd like to have the ability to leave the refrigeration on at the panel once I turn off the battery switches and was hoping some insight as to how the bilge functions with the batteries turned off would be helpful.
Thanks, Shannon
Thanks, Shannon
