Absolutely! That song, that album, that band is part of what made me who I am.Love the soundtrack for the iceboat video. Always was a personal favorite!
- Will (Dragonfly)
Second that. The only band I was ever really a "fan" of. So many poignant memories attached now.Love the soundtrack for the iceboat video. Always was a personal favorite!
Amazing!@rgranger,
I just came across this picture while looking up something completely unrelated. Thought you would appreciate it most of all.
Not a crab claw rig, but you described a version of this, I think.
- Will (Dragonfly)
That was a nice video. I could not see the steering oar so I was confused as to how he was steering the boat.Check out this tacking process to reverse direction.
-Will (Dragonfly)
No. I don't see that. Did you see him tack around the buoy? He changes directions by moving the tack from one end to the other. Sail is on the leeward side the whole time.I wonder why he has his sail on the windward side of the mast. That is generally considered the less efficient tack for that type of sail.
What I saw, he did not really tack around the bouy. He went beyond it then moved the sail and went in the opposite direction over the top of the bouy. The sail moves along one side of the boat. From bow to stern. Wind stays on the same side of the boat. The stern now becomes the bow and he heads back in the direction he came from. Not sure of his method for steering his craft but guess it is a paddle. The sail stays attached to one side. Appears stable. Suspect it is a mono hull with an ama.Did you see him tack around the buoy?
The hull looks a look like a Mad River canoe, to me.Suspect it is a mono hull with an ama.
This type of tacking is called shunting... but look again. The sail is in front of the mast and to the windward side of the mast. On most proas the crab claw sail is behind the mast (on the leeward side of the mast). I have several books on proa designs and have purchased the plans to one called the wa'apa. It looks like it would be a tone of fun to sail. My daughter and I also built a strip planked canoe two summers ago... so I have it in the back of my mind to build a working proa someday. Just need time and space. Right now I have no time...What I saw, he did not really tack around the bouy. He went beyond it then moved the sail and went in the opposite direction over the top of the bouy. The sail moves along one side of the boat. From bow to stern. Wind stays on the same side of the boat. The stern now becomes the bow and he heads back in the direction he came from. Not sure of his method for steering his craft but guess it is a paddle. The sail stays attached to one side. Appears stable. Suspect it is a mono hull with an ama.
I'm afraid I don't see that at all.look again. The sail is in front of the mast and to the windward side of the mast.
I just saw this on Craigslist while looking at small sailing dinghies that I might use as a tender.I also enjoyed this book a lot
https://www.amazon.com/Chinese-Sail...sr=1-2-fkmr0&keywords=How+to+build+a+junk+rig
